Control Group
Tobra's Avatar
Effective means to secure something to a cinder block wall
I have an x-ray processor for which I have built a small stand. My plan is to secure the processor to the stand, and secure the stand to a cinder block wall. The question is, how best to do so? I was thinking I would drill a few holes and using epoxy, mount some threaded stock to the wall, like wheel studs sort of, and bolt the rig to the wall.
Any thoughts or suggestions on this project?
There will be a bit of plumbing to do, also need to make the room light tight, but that should be relatively straightforward.
TIA
Old 09-06-2010, 11:54 AM
Danny_Ocean's Avatar
Assuming the block is hollow and not filled, I would use Hilti toggler anchors in the appropriate size for the weight of the object. No-go on epoxy/threaded rod...
http://www.us.hilti.com/holus/page/module/product/prca_rangedetail.jsf?lang=en&nodeId=-77338
Old 09-06-2010, 11:59 AM
Dottore's Avatar
TIA
No, but I just wanted to point out that line about Europe at the bottom of your posts is wrong and quite inane, and makes you look a bit silly.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 09-06-2010, 12:01 PM
Don Ro's Avatar
In addition to your mechanical approach, you might consider PL's concrete adhesive. I've used it and some other PL products with excellent results...from concrete repair to re-attaching Vibram soles to boots (7 years ago).
PL Sealants, Adhesives, Construction Adhesives, Polyurethane Sealants, Canned Adhesives, Wood Repair Products
Good luck.
Edit: I get it at Home Depot
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 09-06-2010, 12:05 PM
peppy's Avatar
I have good luck with Tapcons.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-06-2010, 12:06 PM
Tapcons may not be good for block, especially when significant weight is involved. Sometimes the block is too "crumbly". If the hole isn't drilled properly, the Tapcon could lose its' bite. They are brittle, too. Tapcons work good in solid concrete.
Old 09-06-2010, 12:22 PM
peppy's Avatar
Danny I put them in the joint, but your are right about them in block.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-06-2010, 12:26 PM
The joint is mortar. I think they'd be better off in the block.
That being said, weight is the issue. I use Tapcons in block all the time to attach plywood or studs. Never when securing something heavy, though.
Old 09-06-2010, 12:29 PM
A930Rocket's Avatar
If the weight of the machine is carrried by the stand on the floor and you're just trying to stabilize the stand to the wall, then some tapcons held in with some two part Simpson SET epoxy from would work. If you can get the stand flush to the wall, you can epoxy it to the wall as well.
If you can position the stand where you can access the vertical mortar joints, you can use 1/4" or 3/8" diameter Redheads with some Simpson SET epoxy as well. This would be the strongest area to work with as the head joints should be filled with mortar.
SET High Strength Epoxy-Tie® Anchoring Adhesive ~ Simpson Strong-Tie Anchor Systems®
Old 09-06-2010, 01:13 PM
wdfifteen's Avatar
Listen to him. The guy knows what he's talking about. Epoxy redheads into the mortar joints.
Old 09-06-2010, 07:07 PM
You do not have permissi
john70t's Avatar
Drilling into concrete has never been precise from my experience. The concrete bit will hit a larger partical and readjust. When locating the studs, mabye attach them to the stand first, then epoxy everything in place.
Hope the stand is not damaged.
Danny's Hilti toggler anchors are the strongest provided they land in a hollow.
Old 09-06-2010, 07:08 PM
A930Rocket's Avatar
I should have noted the block wall should be free of all paint, etc. before trying to attach anything. Otherwise there will be a lack of adhesion, and the part will give way. Clean the hole/surface with a brush and air of all loose drilling debris.
Old 09-06-2010, 07:40 PM
Senior Member
I always go in the center of the cell on the block and use a Hilti or toggle. Never an issue...
Old 09-06-2010, 09:01 PM
How about drilling through all the way to the other side and run a long threaded rod with a big o' washer or steel plate on both side and crank down on the nut? Cut the rod off with a small grinder after. a bit more more work but stronger then anchors.
jeff
Old 09-07-2010, 12:55 AM
