AutoBahned
Refinish Front Door Threshold
what should I do with this?
I'm looking for a low cost, low labor long-wearing approach (!)
Senior Member
Polyurethane. Strip (maybe), sand and coat. And coat. And coat. And coat.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Sikkens has a deck coating that you can get in little tiny samplers. The stuff is amazing. Does not peel
AutoBahned
you mean Cetol?
I used that on my deck - all I have is Redwood color tho... if it IS the Cetol, I know a store here that carries the stuff - just have to match the color |
"YOU CANT RACE A CAB."
aluminum- choice of colors or powdercoat. simple never screw with it again.
if there are TROUT..........there are BEARS! |
+1 Simple, cheap and durable
Chuck ------- 70 & 75 911S 96 993 C4S '10 F-150 |
You do not have permissi
Don't you use spar urethane outdoors instead?
