19 years and 17k posts...
azasadny's Avatar
I'm voting on failing hard drive....
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-25-2010, 04:43 AM
My son is my 14 yo IT guy and he is in charge of fixing the 4 laptops floating around our house. Windows XP is a pretty solid platform and is easy to reload the operating system. I think it is running out of support unless you have service pack two or higher. XP was the last OS that doesn't need a key-code to reload, or more specifically one that only has a single use. If you can get what you need off your computer and clean installl the OS, you would be amazed on how it runs better. Sometimes you can only get so far by trying to fix the OS and it just remains buggy and slow. My son actually has had good luck in upgrading some really old laptops to Windows 7. The disk that came with the computer should be a start. Go on line and search "clean install windows XP" and you will find plenty of material.
Old 09-25-2010, 05:54 AM
jtfreels's Avatar
Is it a Dell? Some are bad about the fan clogging and the CPU will over heat, had it happen to me.
Jay
2002 Boxster Speed Yellow
Old 09-25-2010, 06:58 PM
Edministrator
Steve Carlton's Avatar
It's a Chem Book, probably 7 years old. Been very reliable until now, even has the original battery. It's my backup computer and naturally fails while my Toshiba is in the shop.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 09-25-2010, 08:32 PM
entertaining the idea
UconnTim97's Avatar
Wow, my old Dell laptop has been getting slower and slower lately, thanks to the info here I will be cleaning out the fan tomorrow.
Thanks.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 09-25-2010, 08:58 PM
Edministrator
I downloaded Windows Defender because I heard it was good, thinking there might be some sort of virus. For some reason the Symantec process isn't showing up in the Task Manager after I ended the process and re-booted. (I was unable to uninstall it). For some reason I can't check for updates on Windows Defender. I think this has to do with the Symantec being there. When I run a scan with whatever 2006 definitions are on the program, the CPU usage drops to almost zero for a while before it goes back up. I wish I knew what I was doing...
O - $1
O - $2
O - $3
Old 09-25-2010, 11:24 PM
