fastfredracing's Avatar
Any body have any experience with waste oil furnaces?
I am finally biting the bullet, and picking one up next week. Used of course .
This is nearly a no brainer for me. I don't quite generate enough oil to heat for a full season, but I am sure I will have no problem collecting enough, and filtered waste oil is cheap from suppliers
I have been burning wood for the last couple of years to avoid the 6-8 hunderd dollar a month propane bill I used to have to pay in the cold months.
I guess there is a little maintanence involved , it will need cleaned out several times a season, but that should be a lot easier than cutting , loading stacking and cleaning ashes from wood heat.
I had used one the same size I am purchasing in a rented building several years ago, and it really put out the heat. Easily heated a building twice the size I have now.
Bye bye heating bills!
No left turn un stoned
Old 10-14-2010, 05:02 PM
Un-Registered User
I have no knowledge of waste oil furnaces, but I would think that since you are in PA, you might consider a coal stove/furnace. I have 2 stoves and I heat 3600 sq/ft to 70-75 degrees all winter for less than $1000. No electricity required unless I use the blowers.
Don
1988 Targa
Old 10-14-2010, 05:16 PM
19 years and 17k posts...
azasadny's Avatar
Tab Tanner here on this board has a waste oil furnace in his shop...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-14-2010, 06:02 PM
AutoBahned
RWebb's Avatar
what did Pittsburgh or the county & statesay re their regs on this?
Old 10-14-2010, 06:15 PM
Does he have to ask for permission before install a new furnace?
Old 10-14-2010, 07:14 PM
I think it will be amazing to avoid all the bills if you can get the oil. Unless you run a shop and have tons of used motor oil, run a restaurant and have tons of vegetable oil, then you will have to invest in equipment to collect oil. I wouldn't go so far as getting together the equipment and the deal with oil users. I would just buy used oil. Couldn't a local garage sell it to you and then you just run it through a filter? How fine does it have to be filtered?
Old 10-14-2010, 07:16 PM
AutoBahned
RWebb's Avatar
Yes, in many places.
Old 10-14-2010, 07:50 PM
Autobahn Garage
I have had a Lanair furnace for 4 years and I would not recommend buy one from them. Customer service was in the toilet, It was always needing something, even the NEW parts I bought from Lanair were defective and to top it off there a bunch of Bible beaters that hide behind the cross and rip people off. NEVER BUY FROM LANAIR!!!!!!!!!!!!!!
So I installed a Clean Burn furnace, Great customer service, fast set up and delivery. I have NEVER heard a bad thing said about Clean Burn. Plus the unit is built like a Brick sh-t house, I'll keep you posted once I turn it one for the season
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 10-14-2010, 08:42 PM
Super Moderator
cstreit's Avatar
I don't think these are certifiedfor residential use anywhere. Additionally even the best injection units (which are in the 5k-10k price range) need regular cleaning so unless you wantto be in there once a week cleaning, scraping, etc... I'ts really not such a hot deal.
Great for garages, notsomuch for houses IMO.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-15-2010, 04:50 AM
Friend of Warren
As I recall Fastfred is a mechanic with his own garage in PA. If so that is what makes a waste oil heater so economical to use as he will be able to use waste oil that he used to have to pay to dispose of. One of my clients is also a mechanic with his own garage and uses a waste oil heater to heat his garage. Works really well.
Kurt V
Old 10-15-2010, 05:08 AM
MAGA
Tim Hancock's Avatar
Tab, I have a nearly full 55 gal drum.... Let me know when you want to come get it and swap me an empty drum. (PS... my Bobcat runs now, so it will be much easier to load into your vehicle)
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-15-2010, 06:21 AM
Originally Posted by cstreit View Post
I don't think these are certifiedfor residential use anywhere. .....l.Great for garages, notsomuch for houses IMO.
That was my understanding.
Old 10-15-2010, 08:41 AM
You do not have permissi
john70t's Avatar
There may be restrictions in insurance or lenders policies. City/county regulations may force you to spend a gazillion on building certified storage as well.
Then onto the permits and inspections process...
Best to check all this before buying.
Old 10-15-2010, 09:41 PM
meister member
speedracing944's Avatar
Wood logs soaked in oil is the original waste oil burner.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-16-2010, 06:09 AM
I have done this, and also have had two different home made wast oil furnaces. They rocked out heat, but had no safety devices, and I felt real uncomfortable letting them run unattended.
A waste oil furnace is approved in my building , there are several other local garages running them as well.
I will not be filing for any permits, or asking permission. Christ, I have been burning wood for the last couple of years, and I am sure that is not approved in a commercial building.
Old 10-16-2010, 06:16 AM
AutoBahned
RWebb's Avatar
You would be wise to check into what is required and what the penalties are if you get caught doing it illegally.
They may have a type approval that requires little. OTOH, the penalties could be huge.
Old 10-16-2010, 11:12 AM
abit off center
cgarr's Avatar
Isn't it kind of hard to hide a waste oil furnace?
______________________
Craig
G2Performance
Old 10-16-2010, 12:15 PM
Fred,
I've had a Clean Burn for 6 years. I have it cleaned once a year and have had zero problems. The guy I bought from was a douche bag and didn't know how to set it
( or any oil burner) up. I use almost 100% synthetic in my customers cars and that required a different nozzle. I called Clean Burn and they had another distributor out the next day He fixed it and it's been flawless since. My shop's 8800 sq ft and I like it at 72 so it works perfect for me. Have not spent a dime on heat since buying it. It's my understanding that they are not approved for residential
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-16-2010, 06:29 PM
I have never seen a waste oil furnace belch out smoke like that photo above. Once they are lit, there really is not that much smoke . That looks more like one of those outdoor burners.
Seriously, I looked into it. A Waste oil is permitted in my bldg, and I am not required to file, or apply for any permits.
Most people I know of that have them have been real pleased.
Thanks for your replies .
Old 10-16-2010, 06:50 PM
Super Moderator
cstreit's Avatar
I have a low end thermobile heater in the shop. It's clean and pretty inexpensive. $1400 and free heat from then on. Takes about an hour to heat the 900 sq ft. No good for house though.
Old 10-16-2010, 07:36 PM
