2001 Beetle Battery Drain
A friends 2001 Beetle 1.8T (POS car by the way) is drawing over 2 amps with the key off.
The drain is through the wire that leads to the alternator. The wire is not grounded, it's in good shape. Just swap the alternator out? |
If the draw stops when that is done - then yes. The internal regulator has died.
Yea, figured that. Don't have a manual....Thanks.
Bad diode?
Tcar is correct - Diode passing current both ways. Take to a shop that rebuilds Alt's..
The insulting part of having to replace an alternator or starter on a newer Volkswagen is that any time the battery goes dead, or is unhooked, you have to plug a laptop into the OBD data link and reprogram the ECM's basic settings.
:mad: |
Really???
So if you leave the lights on, and the battery goes dead the average owner will have to have it towed to a service center? That is insane. |
the readiness codes will reset after 5 drive cycles or 50 miles (unless the functions can run because the outside parameters are met) whoever told you that is a liar and an idiot, you do not in any way shape or form need a laptop to "reset any basic parameters" in ANY VW |
Good. I don't have a VW but I could not imagine a dead battery making a car need a trip to a service center.
| All times are GMT -8. The time now is 08:58 AM. |
