2001 Beetle Battery Drain
A friends 2001 Beetle 1.8T (POS car by the way) is drawing over 2 amps with the key off.
The drain is through the wire that leads to the alternator. The wire is not grounded, it's in good shape.
Just swap the alternator out?
Old 10-21-2010, 06:32 AM
Still Doin Time
asphaltgambler's Avatar
If the draw stops when that is done - then yes. The internal regulator has died.
Old 10-21-2010, 06:43 AM
Yea, figured that. Don't have a manual....Thanks.
Old 10-21-2010, 07:42 AM
Bad diode?
Old 10-21-2010, 03:26 PM
LakeCleElum's Avatar
Tcar is correct - Diode passing current both ways. Take to a shop that rebuilds Alt's..
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-21-2010, 07:40 PM
Fast Acting, Long Lasting
The insulting part of having to replace an alternator or starter on a newer Volkswagen is that any time the battery goes dead, or is unhooked, you have to plug a laptop into the OBD data link and reprogram the ECM's basic settings.
Eighteen ways to burn fuel.
Old 10-22-2010, 04:08 AM
Really???
So if you leave the lights on, and the battery goes dead the average owner will have to have it towed to a service center? That is insane.
Old 10-22-2010, 05:21 AM
is this thing on?
NICKG's Avatar
does the car have an aftermarket radio? did you inspect the fuse panel above the battery, these were recalled and it is possible that this one did not have it done.(this is exactly what it does )
that is simply NOT true....
the readiness codes will reset after 5 drive cycles or 50 miles (unless the functions can run because the outside parameters are met)
whoever told you that is a liar and an idiot, you do not in any way shape or form need a laptop to "reset any basic parameters" in ANY VW
"People willing to trade their freedom for temporary security deserve neither and will lose both"
~Benjamin Franklin
Old 10-22-2010, 05:37 AM
Good. I don't have a VW but I could not imagine a dead battery making a car need a trip to a service center.
Old 10-22-2010, 05:40 AM
