How do I fix drywall that's separating in the corner?
Square room has one corner that is separating. The split is about 1/4" wide. Should I just caulk or remove original tape and retape/spackle/sand and paint?
Run smooth, run fast
Retape, mud it, sand, prime, and paint.
Do you have any idea when it began separating? You don't want to fix it, then have it come apart again because there is some issue with part of the foundation settling/sinking near that corner... or termite damage allowing a floor to drop. Is it near an outside wall?
- John "We had a band powerful enough to turn goat piss into gasoline." |
