Tire leak
I have a tire that loses 2 psi per week. How do I find the leak? It is not the valve stem, new. Soapy water in the bead shows nothing. It started after the tire had been on about 2 years.
I was thinking of filling it with R134 and using an electronic leak detector but it is hard to get fittings that will allow that.
Rick
88 Cab
Old 12-27-2010, 11:31 AM
Might be the wheel. You can always put a tube in it.
1990 Wanderlodge PT-40
75 911S Silver Anniversary
1952 MGTD
1983 Mercedes 300 TD
1969 Lincoln
Old 12-27-2010, 11:35 AM
pwd72s's Avatar
Tire shop with a total dunk tank could find it...
Old 12-27-2010, 11:40 AM
enzo1's Avatar
76' 911s Signature Edition
Old 12-27-2010, 11:42 AM
I was thinking of putting it in a kids plastic pool when it gets above freezing but would that show up that size leak?
Rick
88 Cab
pwd72s's Avatar
Dat's it...
Old 12-27-2010, 11:43 AM
enzo1's Avatar
let an experinced guy do it, won't cost much..... if u found it u would still need to fix it, might not get charged unless they find it, usually
Old 12-27-2010, 11:48 AM
pwd72s's Avatar
Yep...tire shop I go to has a tank that has a "hold down" device...keeps all submerged. They test every new mount they do, hand torque the wheels on. That's why I use them.
Old 12-27-2010, 11:50 AM
Senior Member
Superman's Avatar
Spray soapy water on it. The leak will blow a bubble you can easily see. If the leak is in the tread part, and if you were as reckless as me, then you might just ream the hole and put one of those fiber/glue plugs in it.
Mocha 1978 911SC. "Coco"
Old 12-27-2010, 12:07 PM
BTDT If I could find it.
Rick
88 Cab
Old 12-27-2010, 12:36 PM
meister member
speedracing944's Avatar
Bathtub with dishwashing detergent. Submerge the tire or splash soapy water all over it. Look for bubbles.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-27-2010, 12:39 PM
Grog's Avatar
Did you check around the base of the valve stem and the valve core? (the valve core can be tightened with a valve core tool)
To pwd72s, you must not be going to Les schwabs.
1972 Dodge Challenger
2011 Raptor
2013 Road King 110th Anniversary
2014 Corvette Z51 stingray
Single after 27 years married.
Old 12-27-2010, 12:45 PM
VincentVega's Avatar
Pump it full of air and spray soapy water, you'll find it.
Old 12-27-2010, 12:47 PM
pwd72s's Avatar
You got it...Beggs tire over in Albany...great service!
Old 12-27-2010, 12:48 PM
Grog's Avatar
I try to avoid schwabs, I've had around 14 flats since we move to the our current house. I've become an expert plugger. We have a gravel parking area and drive. The last owner just dumped his garbage everywhere. I've been picking up nails, screws, glass old car parts, plastic stuff, wires you name it, it's buried out here. Even found Jimmy Hoffa under a buried bath tub.
2011 Raptor
Old 12-27-2010, 12:58 PM
Senior Member
Superman's Avatar
Yup.
Old 12-27-2010, 02:05 PM
RETIRED
Joe Bob's Avatar
Have you got a wheelbarrow? Fill it with water, dunk the wheel.
2012 ML350 3.0 Turbo Diesel
Old 12-27-2010, 02:26 PM
After all that encouragement... I'll give soapy water another try.
Rick
88 Cab
Old 12-27-2010, 03:05 PM
Senior Member
Superman's Avatar
Borrow your daughter's bubble soap. The leak will might blow a HUGE bubble.
Old 12-27-2010, 03:08 PM
RETIRED
Joe Bob's Avatar
Just fixed the inflatable tire on my two wheeled trolley. It was leaking out the bead.
Deflated it, cleaned the lip of the rim, soaped it and re inflated. No leaky.
Old 12-27-2010, 03:09 PM
