air compressor question- what size lines/fittings ?
As a follow up to my caster question I now need to know what the conventional wisdom is when it comes to plumbing the home shop for air. I have a IR 60 gallon two stage compressor. All of my air tools currently use the 1/4 quick connect size couplers and fittings. Would it make sense to change to the larger 3/8 ? Or does it not matter for the home shop ? The compressor came with massive quick connect fitting it must be 3/4 and 50 feet of rubber hose but it's much too big for air tools. The previous owner was feeding a large sand blast cabinet.
Now onto the air lines. Is 1/4 inch sufficient or should those be 3/8 or larger ? And finally if I'm going to plumb copper around the perimeter of the shop is 1/2 inch sufficient or go with 3/4 ? The air tools I currently have are: 1/4 , 3/8 + 1/2 inch air ratchets 1/2 inch impact wrench detail and full size spray guns DA sander That's it for now but I could add a small blast cabinet in the future plus maybe some additional hand tools. Nothing really volume heavy except for the blast cabinet. So what do you guys use ? |
3/8 hose. I/2 supply lines are fine. Don't be afraid of pvc in this application, although I'm sure folks will chime in that its deadly.
1/4 hose will leave your high volume tools-ie 1/2 impact-without torque. |
I am a big fan of copper. Use a 95/5 or a bearing solder to join fittings.
1/2 would be sufficient for your application. Do a top take off for the line drops and a drip leg and a drain valve under your female connectors. If you are doing any painting you may want to consider filtration for oil and water. |
Yeah, you'd need filtration for water for paint. I love inline oilers for tools, but only at line end so you don't oil the pipes, and you'll need separate hoses for "clean" air then for paint. You can put the separator or oiler on a male fitting and move it for outlet to outlet as needed.
I would be one of those that will tell you PVC is deadly. I have witnessed the consequences of PVC failures in compressed air lines (100-125 psi) first hand and the thought of SHARP shards of PVC flying through the air at a person is not pretty. There are other plastic lines that are rated for Compressed Gas services but I personally do not like them since they are very difficult to install, repair or add to properly. |
My garage is aprox. 23 x 24 with the compressor going in the front left corner. So the copper run will be about 47 feet at its longest run. I'm basically going to make a " U " out of copper with 2-3 drops per side. I will face my quick connect couplers up and will add a drain valve at both ends of the lines. I think 1/2 inch copper is sufficient for this length of run ?
Seamless hydraulic tubing is cheap and easy to install if you can borrow some tools. Just flare the ends and you are done. |
I like the SMC push in connections. You can get them in just about any size and the line you can get in any color. I have this line run all over from my basement to the garage.
http://i30.photobucket.com/albums/c3...1/4f6a1d28.jpg http://i30.photobucket.com/albums/c3...1/659290aa.jpg |
Not to hijack the thread but what would be the recommended minimum rating of a compressor to supply the lines? 5 CF at 90 PSI? or ?
Barry |
SprayGunWorld.com - Professional HVLP Spray Guns
Get hi-flow quick disconnects, scroll down a bit you you will see them.. I got mine locally HVLP Spray Gun Hoses |
Include an inline water knock out pot. I like quick disconnects, get more than a few and keep them handy as you always need an extra one. I prefer the one sold at Sears.
There MANY different makes and when you buy a new tool, you'll need a compatible male end. Nothing pisses ya off more than a QD that don't fit. Nice to be able to reach into a bin and pull one out. Use Teflon tape on the threads. |
[QUOTE=cgarr;5756400]I like the SMC push in connections. You can get them in just about any size and the line you can get in any color. I have this line run all over from my basement to the garage.
http://i30.photobucket.com/albums/c3...1/4f6a1d28.jpg http://i30.photobucket.com/albums/c3...1/659290aa.jpg[/QUOT/] How do you get enough air flow during a draw to power tools? Looks like real small I.D. tubing. Looks like vinyl tubing to boot. |
The tubing is SMC choice for this type of operation. Its what we have been using in our plant for better than 15 years without any problems. http://i30.photobucket.com/albums/c3...1/adcb6e93.jpg |
Flexible tubing is ok since it does not shatter in failure like rigid PVC pipe.
Below diagram shows the correct way to pitch pipe, drains, risers, etc.
http://www.tptools.com/StaticText/airline-piping-diagram.pdf small line may flow enough, but will have pressure fluctuations when demand changes. One more for NOT using PVC: http://www.lascofittings.com/supportcenter/CompressedAir.asp |
http://www.smcusa.com/sections/products/prodoverview.asp |
I read that 50' of 3/4 black pipe before the water separator will cool the air enough but when I use my cheap sandblaster it still turns into a water nozzle.
| All times are GMT -8. The time now is 06:03 AM. |
