enzo1's Avatar
The garage journal
Garages at Night Thread - The Garage Journal Board
76' 911s Signature Edition
Old 01-02-2011, 11:51 AM
UnRegistered User
billybek's Avatar
Cool thread!
Thanks for sharing the link!
Bill K.
Old 01-02-2011, 12:38 PM
Seahawk's Avatar
The Garage Journal is an amazing place...I joined when I reworked one of my barns into a shop. Very smart folks in all aspects of garage gouge.
1996 FJ80.
Old 01-02-2011, 01:02 PM
enzo1's Avatar
Garages | Build Threads
Old 01-02-2011, 01:08 PM
Doug E's Avatar
Neat thread ... thanks !
Doug
'81 SC Coupe
Old 01-02-2011, 03:19 PM
Did you get the memo?
onewhippedpuppy's Avatar
So much to lust over. Right now my primary motivation towards finishing the basement in my house.....the garage is next!
‘07 Mazda RX8-8
Old 01-02-2011, 07:55 PM
my new garage toy
the beam on the right side of pic 2 can be set up to handle at least 10,000# in case i have to sling a boat or raise a 6 cylinder Cat and tranny
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-05-2011, 11:48 PM
Parrothead member
VINMAN's Avatar
Ron, are those simpson ties the only thing holding that beam up??
Vinny
Old 01-06-2011, 05:47 AM
yep
30" simpson strongtie strap and screws into 11 sets of rafters comes out to about 100#/rafter pair. They are not deck screws. Technically simpson doesn't list specs for its screws being used like this but says it's trying to construct a chart . Text says to use nails. For instance deck screws is the worst thing to use.
each rafter set peak will receive a 36" 2x6 joist on opposite sides of the hoist header and on top of the header will receive a 30" simpson strap all attached by 1/4" x 3" simpson screws for overkill. A 150 screw box is expensive.
it's not code and can be turned into a coat rack. Around here if it's not nailed it can be considered temporary. The hoist itself is designed to not be able to lift more that 125% of its rating or it goes kaput. There are better commercial hoists around but i wanted the flash due to helping maintain the house's flash value.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-06-2011, 06:42 AM
