-   -   Edumecate me on Portable Generators. (http://forums.pelicanparts.com/off-topic-discussions/583761-edumecate-me-portable-generators.html)
Joe Bob 01-05-2011 09:52 AM
Been cruising Craig's List and I see not much difference in used generators and new. SO, if I'm gonna get one might as well go new, warranty and one that I want as opposed to "settling".
My needs, can run a full sized microwave, window AC, a Makita portable air compressor, my tent trailer and is QUIET! Long run time, 8+ hours on one tank would be a bonus.
Crowbob 01-05-2011 10:16 AM
Two Honda eu2000i's can be carried easily by one man and put out 4kw peak. Quietest gens on the market. An added benefit is they are pricey.
Seahawk 01-05-2011 10:22 AM
Here is a good link what electric equipment draws.
How to Choose a Portable Generator for Your RV | eHow.com
Honda gens are tough to beat.
sammyg2 01-05-2011 01:09 PM
Herer's a better link:
http://forums.pelicanparts.com/off-topic-discussions/264860-does-anyone-want-free-gererator.html
chocolatelab 01-05-2011 01:11 PM
plus 1 on the honda eu's,
Hugh R 01-05-2011 01:56 PM
If you get the Honda, a lot of people are tempted to throw a lock and cable through the handle. When they get back from the can, they find broken pieces of handle. I attached the cable onto a small metal plate and attached it to a large nut on the exhaust manifold inside the case, then lock it to the trailer. Whatever one you get run Mobil 1 and start it at least once a month. Put Stabilizer in the gas can.
vash 01-05-2011 02:04 PM
i've always wanted an EU3000..for emergencies.
but thinking about it, 2 - EU2000's is probably the better, more versatile choice. the 2000 is easy to carry. the 3000 isnt. my brother runs everything in his pop up with one 2000. he needs a second one running alongs side to run any overhead AC unit.
purely for an "end of days" scenario; it would tough to beat those propane capable yamahas.
944Larry 01-05-2011 07:04 PM
Hugh-gas is so crappy nowadays I haven't had much luck with sta-bil. It still goes bad quickly and gums up the carb. What I do on things I store for a while is put Coleman lantern fuel in them. It seems to never go bad. When I get ready to run something I've stored for a while I drain it out and put fresh gas in it. It will fire right up every time. It's only about 55 octane or so. I wouldn't run any engine on it for long.
Hugh R 01-05-2011 07:41 PM
Larry, interesting, what do you do, put coleman fuel in it and run to flush then switch over when using. My Honda runs like crap right now without boosting the choke, and I run it for 1/2 hour a month. Maybe new spark plug?
Joe Bob 01-05-2011 10:30 PM
More than a couple eu3000s around town for around $800.....
red-beard 01-06-2011 04:31 AM
You have benn ethanol-ed. You now need to replace your carb.
desertt5 01-06-2011 05:34 AM
Here is a good write up with pretty pictures on the Honda carbs. Won't help all of t hem. but much cheaper than a new carb. My 2 Honda EU's haven't has much of a work out to need it yet, but one day I am sure they will.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22602186.cfm
944Larry 01-06-2011 05:04 PM
Yep, I run it just enough to get it running through the carb. I don't always get home once a month to crank things up. When I get ready to use engine I top it off with fresh gas and with the Coleman fuel in it, it'll start every time. An old man once told me "Check the plugs first".
Red88Carrera 01-06-2011 05:22 PM
If you can find an EU3000is for $800, you better grab as many as you can. I paid $1785 for mine.
http://www.frontiernet.net/~ddturner/gen.jpg
Lothar 01-06-2011 05:41 PM
I have a Yamaha 2800W Inverter generator. Makes a clean power and is very quiet. I would highly recommend Yamaha.
desertt5 01-07-2011 08:57 AM
From the Yamaha's I've heard run and the owners I 've talked to, they are equal to the Honda's. Thier price is eqaul also.
vash 01-07-2011 09:00 AM
gotta link? i'd get one if i could buy it for $800.
Joe Bob 01-07-2011 11:02 AM
Sacramento CL.
cashflyer 01-07-2011 11:29 AM
Nothing beats a Gererator for quiet power output and reliability.
Joe Bob 01-07-2011 11:35 AM
Honda EU2000i Inverter Generator w/ Triple-Fuel System - eBay (item 230569537046 end time Jan-09-11 14:46:24 PST)
Propane power for the Honda generator.
