Double Trouble
Netflix streaming to bluray
I got an LG unit that will allow streaming to my TV from netflix. Is that all I need? How do you get it hooked up? Do I need any additional stuff to hook it up?
Information Junky
iirc, plug in a LAN cable. . then you scroll (from your tv) to the Netflix 'gadget'/app and it will give you a code, and ask you to go online to register that box to your account. go to the Netflix site, and follow the directions.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
When it was first made available, Netflix sent us a DVD that we needed to insert on our PS3 in order to see our content. They have since released an app for PS3, so I would think it is done in one of the two ways on your player. At the most you will need a DVD disc from Netflix which arrives within a day or so of ordering it. This might be helpful if you have not been there already:Netflix: Rent as many movies as you want for only $8.99 a month! Free Trial
I can see no reason why there will be a need for any other additional stuff.
Neil 87 944S http://guns.claasen.us/ |
I recently did this via WiFi with a Samsung player.
Works (now), but required me to update my wireless router. Real big hassle to get the two to talk to one another. But, once that was done - it works pretty well. I do have issues with either Netflix or my cable supplier's speed. I'm guessing it's the cable company. They claim that if you have 2GPS (please don't roast me if this is not the correct term) available, it will work. Once in a while the movie stops while the download "catches up". Also - picture quality can vary from the low end of high def to downright crappy. I'm sure based on connection speed as well as traffic on the Netflix end. Their current menu setup is pretty nice. Changed (software) about 1-2 mos ago. Much easier to navigate than the previous interface. |
Double Trouble
Do I need an ethernet adapter kit? Just what do I plug the unit into? My modem? I only have one outlet on my modem and it connects to the Mac,. i know these sound like stupid questions to some of you but i challenged here.
Information Junky
most require a LAN cable. (some may be wifi)
If you have a wireless router (wifi box) it will likely have sockets, in the back, to plug-in a LAN (jumper) cable to the new blueray box. ...allowing the new box to talk to the interweb's goodness
I stream netflix on several devices. Works very well. Picture quality is usually very good with an occasional delay due to buffering.
Randy '87 911 Targa '17 Macan GTS |
This sounds like you have a modem only. One phone jack to plug into the wall (or maybe coax if it's a cable modem) and one ethernet jack to plug into your computer. If you plug a router into the ethernet port of your modem (the one your Mac is currently using) you can then use your router to connect multiple devices. You can connect an ethernet cable from the router to your Mac, and another ethernet cable from your router to your BluRay player. Or get a wireless router and connect wirelessly. Cables are simpler to use if you're a novice.
Aaron '81 911SC RoW Targa |
My sony can use a usb wireless or a cable. since my router is in the same cabinet I just used the cable. My setup was exactly as Island said.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
New kid in town
But as has been stated, the first step is getting the device to talk to the internet. This is better with a wired connection, but I run just fine over wireless.
I wish I still had 9111113443... |
Alternatively, if you want to test it out you can try disconnecting your Mac and connecting your BluRay player to see how well it works. Switch the cable, then reboot everything and test it out.
Sounds like your BluRay player has some type of Netflix software already loaded on it. This would be a quick proof of concept.
Aaron '81 911SC RoW Targa Last edited by Head416; 01-06-2011 at 11:47 AM.. |
Information Junky
You could buy a router - they are essentially just like a power-strip...but for your LAN (Local area network) ...extending how many lines can feed thru one cable. $13 Amazon.com: TRENDnet 5-Port Ethernet Switch (5 x 10/100Mbps Auto-MDIX RJ-45 Ports) TE100-S5 (Blue): Electronics or get a wifi version for not much more.
That looks like a switch that would not NAT his multiple devices behind the one IP assigned by the ISP. I think if he used that the first device to boot would get the IP and the rest wouldn't work.
I could be wrong. It has happened before. It's been a long time since I had a separate modem and router.
Double Trouble
i'm on a wire.
Information Junky
I dunno ... just grabbed and posted the first cheapy router
how about this @ $19 Amazon.com: Belkin Wireless G 4-Port Router: Electronics
Perfect.
Double Trouble
Double Trouble
Are there any routers that are better than others? (wired) Anything as far as specs I should look for?
If going wireless (and you need to make sure unit is wireless ready), netgear is NOT a good choice. I had to ditch one and go cisco. If hardwired, probably not as big of a deal.
And if you are going to do it - go wireless N!!
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
