Had a generator. Last edited by tcar; 01-13-2011 at 04:17 PM.. |
VWs have been negative ground forever. That car had few electronics to fry, so having the battery connected backwards shouldn't have ruined anything but the radio. Does the generator seem to be charging? If it is, it's polarity has gotten reversed and you may have to repolarize it.
Polarizing Your Generator I can't understand how you would get -12 volts anywhere except by connecting the + (red) probe of the meter to something that is connected to the - post of the battery, and connecting the - probe to something connected to the + battery terminal.
vw's have starters?????????????????????????
why did we always have to push mine???????????
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
not much to fry in a bug. regulator, radio, thats about it.
the speedo was still a cable to left front wheel.
Isn't the voltage regulator mounted under the seat right next to the battery? Had a flap of cardboard over it to protect it from shorting out. Is negative hooked to these terminals as well? I had a few of these as well back in the day.
Just trying to remember but I think thats right.
Kevin '79 Coupe |
Double Trouble
Double Trouble
IIRC, 12v cars had the regulator mounted remotely.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
abit off center
Here is a 72 Should be much the same: Pay no attention to the red ground cable!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Seldom Seen Member
Then why did I always have to park on a hill?
Why do things that happen to white trash always happen to me? Got nachos? |
Control Group
because it aspired to be a 914
She was the kindest person I ever met |
I'm with Bill
Now looking at that batt, it is hooked up correctly. Note the 3 holes over the one post. That is for a B+ cover. the B- doesn't have a cover because it isn't required.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I thought the batteries slid along the ground under the car.
The cables went thru the hole in the floor. |
