Hi
1969 VW Bug Question
A buddy just bought a 69 bug.
And in checking things out we've noticed that the POS post cable of the battery is bolted to the chassis and the NEG post cable of the battery disappears into the engine compartment, most likely goes to the starter. Is this how the old bugs were set up? I use to own a bug but I've forgotten how the battery cables were set up.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Negative should be attached to the chassis and the positive goes through a hole in the chassis to the starter.
Are you sure that what you think is + is really +, and same for - ?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I thought only the Brits used positive ground?
David 1972 911T/S MFI Survivor |
VW's are negative ground.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Flip the battery around.
dolor et pavor Copyright |
Un Chien Andalusia
I once had an '67 MGB that was originally +'ve ground. Obviously the engineers didn't think that through very well, or completely forgot about electrolysis when the decision on how to hook up the electrical system was being made.
Certainly wouldn't expect the Germans to do such a thing.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Hi
Hooked up a DMM to the car, Pos batt to chassis and it read -12vdc.
OK, it's backwards. I shudder to think what else you have going on....
I have owned three '69 Bugs and a '69 K-Ghia... all were negative ground.
You may have big problems. Is the battery dead? As far as I know, they were all negative ground. They switched from 6V to 12V in 67, I think. I remember that all Fords in the '50's were positive ground AND 6 Volt. Last edited by tcar; 01-13-2011 at 04:02 PM.. |
Fast Acting, Long Lasting
Y'all know you can charge a battery up backwards, as in, reverse the polarity? Old boss' dad did that accidentally on a Stupid A tractor. Fella didn't know he'd done it until the battery went dead again in the field and he checked it with a volt meter.
Eighteen ways to burn fuel. |
FWIW I hooked the battery up backwards in the 356 when I was young (about 12, Dad was original owner). Car ran fine but the tach wanted to go backwards...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
abit off center
When you drove it did you have one speed forward and four reverse?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Control Group
Man, you best check that car out double close before you drive it anyplace, especially stuff that can kill you, like brakes and fuel lines, your DAPO probably did a lot of things wrong.
She was the kindest person I ever met |
Un-Registered User
If the cable on the + teminal is now going to the chassis, and you hooked up a DVM/DMM between the Pos Batt terminal and the chassis, it would read zero volts, not -12vdc.
Don 1988 Targa |
Hell Belcho
On a bug, the battery sits under the backseat and negative bolts to the chassis. The 12V positive cable goes directly to the starter motor.
Here's what im thinking. I once helped a friend out with an old BMW where he saw a red and a black cable. He hooked the battery up red to POS, black to NEG. He fried the electrical system. After looking at it, I realized that the red cable was actually brown. He thought that the red had faded to that color. On German cars, Black is 12V and brown is ground. Can you post a picture? If I recall correctly, the NEG cable should be a braided strip. One other thing, Does the car have an alternator or a generator? I seem to remember having to modify the wiring on a few bugs because the original generator was no longer available and an alternator had to be used. I think that some alternators back in the day had to be polarized before you used them.
Saved by the buoyancy of citrus. |
Hi
I'll try and post some pics tomorrow.
Control Group
Braided cable, yeah, seem to recall the negative post goes out board. They could have replaced the ground with something funky though
Hi
LOL, no. I don't the engine would run in reverse. That would mean #4 cyl is acting as #1 and I believe the timing would be off.
RETIRED
12v positive ground, last 6v in 66, should have a 1500cc single port Type I engine.
