Hi
Targa Me's Avatar
1969 VW Bug Question
A buddy just bought a 69 bug.
And in checking things out we've noticed that the POS post cable of the battery is bolted to the chassis and the NEG post cable of the battery disappears into the engine compartment, most likely goes to the starter.
Is this how the old bugs were set up? I use to own a bug but I've forgotten how the battery cables were set up.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 01-12-2011, 02:29 PM
Negative should be attached to the chassis and the positive goes through a hole in the chassis to the starter.
Are you sure that what you think is + is really +, and same for - ?
Old 01-12-2011, 02:35 PM
I thought only the Brits used positive ground?
1972 911T/S MFI Survivor
Old 01-12-2011, 02:36 PM
pete3799's Avatar
VW's are negative ground.
Pete
79 911SC RoW
Old 01-12-2011, 02:41 PM
Arizona_928's Avatar
Flip the battery around.
dolor et pavor
Copyright
Old 01-12-2011, 02:45 PM
Un Chien Andalusia
Aerkuld's Avatar
I once had an '67 MGB that was originally +'ve ground. Obviously the engineers didn't think that through very well, or completely forgot about electrolysis when the decision on how to hook up the electrical system was being made.
Certainly wouldn't expect the Germans to do such a thing.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 01-12-2011, 02:48 PM
Hi
Targa Me's Avatar
Yup, I"m absolutely certain. The battery has a + molded into the plastic and "that" cable is bolted to the chassis.
Hooked up a DMM to the car, Pos batt to chassis and it read -12vdc.
Old 01-12-2011, 02:57 PM
OK, it's backwards. I shudder to think what else you have going on....
Old 01-12-2011, 03:20 PM
I have owned three '69 Bugs and a '69 K-Ghia... all were negative ground.
You may have big problems. Is the battery dead?
As far as I know, they were all negative ground. They switched from 6V to 12V in 67, I think.
I remember that all Fords in the '50's were positive ground AND 6 Volt.
Old 01-12-2011, 03:31 PM
Fast Acting, Long Lasting
Y'all know you can charge a battery up backwards, as in, reverse the polarity? Old boss' dad did that accidentally on a Stupid A tractor. Fella didn't know he'd done it until the battery went dead again in the field and he checked it with a volt meter.
Eighteen ways to burn fuel.
Old 01-12-2011, 03:40 PM
id10t's Avatar
FWIW I hooked the battery up backwards in the 356 when I was young (about 12, Dad was original owner). Car ran fine but the tach wanted to go backwards...
Old 01-12-2011, 03:46 PM
pete3799's Avatar
This
Pete
79 911SC RoW
Old 01-12-2011, 05:23 PM
abit off center
cgarr's Avatar
When you drove it did you have one speed forward and four reverse?
______________________
Craig
G2Performance
Old 01-12-2011, 05:50 PM
Control Group
Tobra's Avatar
Man, you best check that car out double close before you drive it anyplace, especially stuff that can kill you, like brakes and fuel lines, your DAPO probably did a lot of things wrong.
Old 01-12-2011, 06:57 PM
Un-Registered User
If the cable on the + teminal is now going to the chassis, and you hooked up a DVM/DMM between the Pos Batt terminal and the chassis, it would read zero volts, not -12vdc.
Don
1988 Targa
Old 01-12-2011, 07:07 PM
Hell Belcho
Nostril Cheese's Avatar
On a bug, the battery sits under the backseat and negative bolts to the chassis. The 12V positive cable goes directly to the starter motor.
Here's what im thinking. I once helped a friend out with an old BMW where he saw a red and a black cable. He hooked the battery up red to POS, black to NEG. He fried the electrical system. After looking at it, I realized that the red cable was actually brown. He thought that the red had faded to that color. On German cars, Black is 12V and brown is ground.
Can you post a picture? If I recall correctly, the NEG cable should be a braided strip.
One other thing, Does the car have an alternator or a generator? I seem to remember having to modify the wiring on a few bugs because the original generator was no longer available and an alternator had to be used. I think that some alternators back in the day had to be polarized before you used them.
Old 01-12-2011, 07:51 PM
Hi
Targa Me's Avatar
I'm telling ya it read -12 vdc. (neg twelve volts direct current).
I'll try and post some pics tomorrow.
Old 01-12-2011, 09:20 PM
Control Group
Tobra's Avatar
Braided cable, yeah, seem to recall the negative post goes out board. They could have replaced the ground with something funky though
Old 01-12-2011, 09:22 PM
Hi
Targa Me's Avatar
LOL, no. I don't the engine would run in reverse. That would mean #4 cyl is acting as #1 and I believe the timing would be off.
Old 01-12-2011, 09:23 PM
RETIRED
Joe Bob's Avatar
12v positive ground, last 6v in 66, should have a 1500cc single port Type I engine.
Old 01-12-2011, 09:24 PM
