Metal Garage Kits- Good or Bad?
I need to add another 2 stall garage for storing my Harleys and 4 wheeler. I am considering the metal garage kits I see advertised for around 4200 or so.
I'd like some opinions on this, are they junk or should I build another wood garage and side it to match the house? This building will not be visible from the street. It will be behind the house. |
Senior Member
Where are you located? Makes a BIG difference...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I'm in WV. Our winters haven't been that bad the last few years. With a metal building I was concerned about a roof collapse with a heavy snow.
Somewhere in the Midwest
It probably won't cost you that much more to stick build a simple 2 car garage...simple is the keyword. Start with just footers and gravel the floor for now. The materials for a 2 car garage is in the range of $3500-4000. With either steel or wood, you'll still need footers or sonotubes to support the building. You'll still need a floor...so the big difference is the construction cost...if you can frame and sheat it your self, you'll save some money. Pre-order trusses and you can put the roof up with just two guys. You can even do the roof and siding yourself. The big advantage of a steel building (if it's a kitted building) is erection time. But good framers can put up a stick built garage in less than a day. If you are not running electrical immediately, you can get it inspected and finished in just a few days after the concrete footer cures. Your local building inspector will be willing to work with you to make sure it's safe.
I already have a concrete pad there. It's 25x25 So either way I go the floor is ready. I wont need electric in it. at least not right away.
Then I would definietly stick build it. If you have a compressor (I'll bet a beer you do), order a harborfreight framing nailer, or pay a few more dollars and get one from the local home supply store, a truck load of 2x4's (get treated ones for the base) and start framing. You can order truses delivered to your driveway.
Just as a point of reference, I had 9 trusses made for my 16X16 ft. storage shed. The cost was $450 or $50 ea.
Marv Evans '69 911E |
Dog-faced pony soldier
The prefab units aren't bad but you're really not going to save that much versus wood framing like Souk said... You'll end up with the same permitting issues and costs, etc. The only immediately obvious advantages are non-flammable construction and simplicity of construction.
I like being able to design/build what I want however. The variety of the metal structures is pretty limited - at least the ones I've seen. I imagine they're a PITA to insulate if you ever want to down the road also...
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Yep I do have a compressor. It has a 6hp 4 stroke Honda engine on it so it would be ideal for building this out of wood. You guy have me leaning that way. In the end it would be nicer and might increase my property value a dollar or two.
Thanks for all the advice. |
The Puff.
'70 CT1B '11 GTS 300 Super |
Is it holding up okay? Most of the spray-on foam type insulations I've seen tend to flake off and/or fall to the bottom after a while. If you packed it in there between the ribs and then screwed gyp board onto it it'd probably be okay... You'd have to make sure you had good vapor control on the inside so you didn't get condensation on the inside of the metal skin though or it could start rotting the stuff out.
Just curious. Another benefit I suppose is termites don't eat metal (but again, if you detail it properly they won't get to your wood framing either...)
You need to make sure that your area permits them, where I live, those metal building are allowed in residental areas
![]() One thing going for them is they can be put up very fast (had a 30X40 at the old house), and you can use foam board insulation..
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
The thing with wood is: you can easily modify/add with just nails and a hammer. You can insulate it and drywall over it without getting too fancy. And as Byron indicated...the wood buildings look better than steel buildings.
The Puff.
Your climate is pretty forgiving - was it in your area or a cooler, moister one? Do you know offhand who the mfr. was?
