Somewhere in the Midwest
If needed, you can use 1x1's between the floor joices and the MDF or what every you want to use. Plywood could be cool when stained...but it can be expensive to do the whole basement with plywood. Think of it as would paneling for your ceiling! |
AutoBahned
if it was mine, I'd put in cans where I wanted, then sheet rock it but leave the beam exposed - I might surface the beam with nice trim & natural stain. In fact, that is what I've done in my own (daylight) basement.
whatever, I'd definitely cover the pipes and, yes, white paint |
unindicted co-conspirator
also make sure if you have a bedroom located there that you have an "egress" window with a sill height no higher than 44" above the floor with approx 24" x 30" net opening, or a door that has direct exterior access.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Monkey+Football
Timely thread -
I've just finished the drywall in my basement, time to move on to the ceiling. I've been lookign at this: ACP - Surface Mount Grid System CeilingMAX and this: CeilingLink Direct Mount Ceiling Grid System. Mainly cause I absolutely frigging hate finishing drywall, and want to have access for various cables pulls etc. since it's a home theater and playroom. Ceiling Max you can get at Lowes/Home Despot, and insert whatever tiles you want. Gives you the acustical deadening and finished a lot faster.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
New kid in town
That's an interesting option. How do you handle the duct work?
I wish I still had 9111113443... |
Timely for me as well. Today I just ordered 77 sheets of drywall for my basement. When we bought the house 5 years ago, it had a dropped ceiling with a large duct running down the middle. We moved the furnace and ran the ducting to the side in a soffit. This allowed the height of the ceiling to go full height. We added a bath, laundry and theater room. This out of a space that was really unusable for anything "normal" before we moved the duct. Check it out, if you can recapture that space and make it legit, you will add a huge chunk to your equity.
Larry |
Monkey+Football
I think there's some reference pictures on the CeilingMax site that showed how to handle soffits and boxes for ducts with the tiles if you didn't want to drywall them. The site has good estimating tool and instructions on installation. The expensive part will be the tiles - they can get pricy. Pic:
