-   -   Outlook + Web Mail help please.. (http://forums.pelicanparts.com/off-topic-discussions/599712-outlook-web-mail-help-please.html)
MotoSook 03-28-2011 02:24 PM
I have been experiencing this problem for a while and I thought it was unique to my home desk top. I just didn't bother to fix it on my desk top since I could just log on to the mailbox via the web. I just tried to configure my new HP Slate to sych up with my web mail, and it's experiencing the same problem:
I can download e-mail from the server, we'll call it mail.soukus.com
For the incoming IMAP mail, I have the server set to: mail.soukus.com
and for the outgoing mail I have it set to smtp.soukus.com
I've checked and double checked my password and I still cannot send to the server.
The same config info is on my iphone and it works just fine.
What am I doing wrong on my Windows machine running Outlooks?
Any tips to help remedy this will be greatly appreciated.
Thanks!
stomachmonkey 03-28-2011 02:37 PM
Sometimes simply using the servers IP address resolves it. I find that situation applies mostly to consumer broadband providers.
SMTP has a couple of advanced options, you may or may need to over ride the default port. It may or may not require SSL.
MysticLlama 03-28-2011 02:41 PM
You might need to make sure it sends your password to the outgoing server. There should be a checkbox for that, or possibly one for log onto incoming server first, or something like that.
It also might want secure password auth, every server is a little bit differnet as the the settings it wants exactly, as well as how it wants your username to look, etc.
MotoSook 03-28-2011 02:43 PM
My incoming and outgoing passwords are the same, but just in case, I set the outgoing to provide my user name (e-mail address) and password. Still it no workee.
stomachmonkey 03-28-2011 02:50 PM
Who is your ISP?
MotoSook 03-28-2011 03:23 PM
Currrently we have ATT DSL. We live in the boonies, but prior to our move, I had Comcast. The same problem occured with Comcast cable.
stomachmonkey 03-28-2011 04:01 PM
As stupid as this may sound hang in with me.
Some ISP's block port 25. Both ATT and Comcast are known to do this.
http://kb.siteground.com/article/How_to_check_whether_SMTP_port_25_is_blocked.html
See if you are blocked.
willtel 03-28-2011 04:52 PM
I believe AT&T requires that you log onto the servers using SSL. There is an option for that within Outlook.
stomachmonkey 03-28-2011 05:27 PM
Well they really want you to use their servers for sending so they can monitor usage.
It's a spam prevention thing.
id10t 03-28-2011 08:16 PM
Some ISPs block outgoing mail. You should be using smptauth on port 589 (i think) to connect to your own external server
red-beard 03-28-2011 08:29 PM
use port 2525. AT&T doesn't block 2525.
MotoSook 03-28-2011 08:43 PM
No dice on 589 :(
MotoSook 03-28-2011 08:45 PM
:( no workee
stomachmonkey 03-29-2011 05:57 AM
Is this a work server you are trying to hit?
Who controls the server you are trying to use?
Did you do a port check? Easier and quicker to determine if that's the issue rather than randomly entering alternate ports.
Eric Coffey 03-29-2011 10:30 AM
For outgoing SMTP (for ATT) try:
Under "advanced":
SMTP Port = 465
Check SSL
Under "servers":
Incoming & outgoing -
Check "remember password"
UNcheck "logon using secure password authentication"
Outgoing -
Check "my server requires authentication"
MotoSook 03-29-2011 11:58 AM
Personal server. I tried the port test via dos command. and it didnt work for me. it didnt like "telnet" in the command string.
MotoSook 03-29-2011 12:01 PM
Under "advanced":
SMTP Port = 465
Check SSL
Under "servers":
Outgoing -
This worked!!!!!!! Thank you and thanks everyone for the input! I knew you guys would get it.
cgarr 03-29-2011 12:10 PM
It worked today but tomorrow is another day :D
MotoSook 03-29-2011 12:18 PM
it better stay working...or...or nottin'...I'm stuck with ATT out here.
