Somewhere in the Midwest
MotoSook's Avatar
Outlook + Web Mail help please..
I have been experiencing this problem for a while and I thought it was unique to my home desk top. I just didn't bother to fix it on my desk top since I could just log on to the mailbox via the web. I just tried to configure my new HP Slate to sych up with my web mail, and it's experiencing the same problem:
I can download e-mail from the server, we'll call it mail.soukus.com
For the incoming IMAP mail, I have the server set to: mail.soukus.com
and for the outgoing mail I have it set to smtp.soukus.com
I've checked and double checked my password and I still cannot send to the server.
The same config info is on my iphone and it works just fine.
What am I doing wrong on my Windows machine running Outlooks?
Any tips to help remedy this will be greatly appreciated.
Thanks!
Old 03-28-2011, 02:24 PM
The Unsettler
stomachmonkey's Avatar
Sometimes simply using the servers IP address resolves it. I find that situation applies mostly to consumer broadband providers.
SMTP has a couple of advanced options, you may or may need to over ride the default port. It may or may not require SSL.
"I want my two dollars"
"Brandon Won"
Old 03-28-2011, 02:37 PM
You might need to make sure it sends your password to the outgoing server. There should be a checkbox for that, or possibly one for log onto incoming server first, or something like that.
It also might want secure password auth, every server is a little bit differnet as the the settings it wants exactly, as well as how it wants your username to look, etc.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 03-28-2011, 02:41 PM
MotoSook's Avatar
My incoming and outgoing passwords are the same, but just in case, I set the outgoing to provide my user name (e-mail address) and password. Still it no workee.
Old 03-28-2011, 02:43 PM
The Unsettler
Who is your ISP?
"Brandon Won"
Old 03-28-2011, 02:50 PM
MotoSook's Avatar
Currrently we have ATT DSL. We live in the boonies, but prior to our move, I had Comcast. The same problem occured with Comcast cable.
Old 03-28-2011, 03:23 PM
The Unsettler
As stupid as this may sound hang in with me.
Some ISP's block port 25. Both ATT and Comcast are known to do this.
http://kb.siteground.com/article/How_to_check_whether_SMTP_port_25_is_blocked.html
See if you are blocked.
"Brandon Won"
Old 03-28-2011, 04:01 PM
I believe AT&T requires that you log onto the servers using SSL. There is an option for that within Outlook.
1987 GP White 930
1977 Ford Bronco
Old 03-28-2011, 04:52 PM
The Unsettler
Well they really want you to use their servers for sending so they can monitor usage.
It's a spam prevention thing.
Old 03-28-2011, 05:27 PM
id10t's Avatar
Some ISPs block outgoing mail. You should be using smptauth on port 589 (i think) to connect to your own external server
Old 03-28-2011, 08:16 PM
canna change law physics
red-beard's Avatar
use port 2525. AT&T doesn't block 2525.
James
Red-beard for President, 2020
Old 03-28-2011, 08:29 PM
MotoSook's Avatar
No dice on 589
Old 03-28-2011, 08:43 PM
MotoSook's Avatar
no workee
Old 03-28-2011, 08:45 PM
The Unsettler
Is this a work server you are trying to hit?
Who controls the server you are trying to use?
Did you do a port check? Easier and quicker to determine if that's the issue rather than randomly entering alternate ports.
"Brandon Won"
Old 03-29-2011, 05:57 AM
Eric Coffey's Avatar
For outgoing SMTP (for ATT) try:
Under "advanced":
SMTP Port = 465
Check SSL
Under "servers":
Incoming & outgoing -
Check "remember password"
UNcheck "logon using secure password authentication"
Outgoing -
Check "my server requires authentication"
Old 03-29-2011, 10:30 AM
MotoSook's Avatar
Personal server. I tried the port test via dos command. and it didnt work for me. it didnt like "telnet" in the command string.
Old 03-29-2011, 11:58 AM
MotoSook's Avatar
Under "advanced":
SMTP Port = 465
Check SSL
Under "servers":
Outgoing -
This worked!!!!!!! Thank you and thanks everyone for the input! I knew you guys would get it.
Old 03-29-2011, 12:01 PM
abit off center
cgarr's Avatar
It worked today but tomorrow is another day
______________________
Craig
G2Performance
Old 03-29-2011, 12:10 PM
MotoSook's Avatar
it better stay working...or...or nottin'...I'm stuck with ATT out here.
Old 03-29-2011, 12:18 PM
