-   -   Another question for experienced mechanics (http://forums.pelicanparts.com/off-topic-discussions/600443-another-question-experienced-mechanics.html)
KevinP73 04-01-2011 09:50 AM
This is a pic of the thermostat housing on my Dodge 4.7. Does this look like a failure in the casting or is this just poor machine work?
http://forums.pelicanparts.com/uploa...1301676544.jpg
http://forums.pelicanparts.com/uploa...1301676599.jpg
Scott R 04-01-2011 10:43 AM
Common problem, timing cover is disintegrating. You will likely find rust in the radiator and heater core with this issue. Coupled with a mysterious overheating issue that you can't seem to fix.
You need the cover, gaskets, pump and radiator flush with an entire cooling system flush. Not a fun project given where that cover is.
KevinP73 04-01-2011 11:01 AM
Research supports your reply. The dealer wants $367.00 my cost for the cover. e-bay has some from Allstar Automotive in Denver for $35.00-$70.00 but not being able to inspect it in person makes me a little leary to buy used.
