winter-hater club member
nynor's Avatar
ford 302 rockers/pushrods: replace?
i am in the middle of helping a friend do a cylinder head job on his ford truck. the heads are on. the problem is that the rocker arms got scrambled due to a freak wind storm. the pushrods are all labelled and oriented, but half of the rocker arms lost their labels.
question: should he replace the rockers/pushrods, or will it not matter?
thanks, pelican brain trust!
d.
"COOL PRIUS!" - Nobody Ever
Old 04-30-2011, 07:03 AM
Jim Bremner's Avatar
I would just toss the rockers in and don't worry. It's just a truck engine and has hydrolic lifters. shouldn't be a issue.
I would worry more about the pushrods.
Now if you're trying to zing that motor to 7k or greater I would worry
Old 04-30-2011, 07:09 AM
Unregistered
sammyg2's Avatar
If you had new valves and pushrods I might say replace the rockers, but it's a ford 302 so you know it'll never see much over 5000 rpm.
I'd install the old ones as long as they don't show any unusual wear patterns.
Old 04-30-2011, 07:34 AM
My 17 year old son has a 1989 gt mustang as a first car.
I was testing some things out in the car. I had just driven the corvette and jumped into his. 4,800 rpm and it hit the wall
My 302 based 331ci engine in my mustang made more hp at 2,800 and started coming on at 3,000 at 6,400 it was making 364 at the rear wheel and would run up to the 7,100 rev limiter
Old 04-30-2011, 07:48 AM
Banned
speeder's Avatar
Just make sure that no push rods are bent, visually inspect the rockers @ contact points for anything unusual and throw them in. It will be fine.
Old 04-30-2011, 08:55 AM
A930Rocket's Avatar
Good advice above. Push rods are cheap if you replace them.
Are they roller rockers? Either way, they're cheap too if you want to replace them.
Old 04-30-2011, 08:59 AM
Banned
m21sniper's Avatar
d.
Doesn't matter.
Old 04-30-2011, 11:06 AM
Fast Acting, Long Lasting
It's a Ford Windsor engine. You could overhaul the thing on a gravel driveway, and it wouldn't matter. Playing musical rocker-arms isn't going to cause any trouble.
Eighteen ways to burn fuel.
Old 04-30-2011, 01:07 PM
nynor's Avatar
thanks guys!
Old 04-30-2011, 05:11 PM
