-   -   I need help wiring my driving lights (http://forums.pelicanparts.com/off-topic-discussions/607350-i-need-help-wiring-my-driving-lights.html)
trekkor 05-07-2011 06:51 PM
Adding two pairs of lights for our upcoming 24 hour race next weekend.
I want to use the factory wiring.
I removed the headlights from the car a while ago, but carefully reserved the wiring.
I want to wire the one set through the low beams and the other through the fog lights.
I can't get the wiring to power up.
It makes no sense.
KT
9dreizig 05-07-2011 07:11 PM
Call me
fastfredracing 05-07-2011 07:16 PM
Is this on the lemons car, or on your real track car?? I am up at the shop right now, I have access to all of the wiring diagrams if you need.
9dreizig 05-07-2011 07:20 PM
This is the lemons car Fred,, I'm talking to him on the phone right now..
fastfredracing 05-07-2011 07:29 PM
If you need anything, let me know, I should be up here till about midnight, spinning bolts on the 930 right now.
porsche4life 05-07-2011 07:43 PM
You gunna need me to Southern engineer it when I get there?
trekkor 05-07-2011 09:51 PM
Quick fix.
Todd suggested checking the headlight relay.
I had a spare.
That was it.
I'm all wired up and ran the car for about 45 minutes with all the lights on.
Even with the underdrive pulley, the alternator still produces 14.3 volts with 300+ watts of lights at idle.
KT
9dreizig 05-07-2011 09:53 PM
Sid,
I need your flights and we need to talk about gear etc.. give me a call tomorrow
trekkor 05-07-2011 10:07 PM
Don't let me forget to get you a crew member's wristband, too.
We'll be counting you for fueling/driver changes and mechanicals.
KT
trekkor 05-07-2011 10:10 PM
The lights!
http://i944.photobucket.com/albums/a...p/P1110585.jpg
http://i944.photobucket.com/albums/a...p/P1110586.jpg
http://i944.photobucket.com/albums/a...p/P1110587.jpg
http://i944.photobucket.com/albums/a...p/P1110588.jpg
KT
porsche4life 05-07-2011 10:10 PM
Originally Posted by 9dreizig (Post 6009024)
Sid,
You be around tomorrow evening? I'll give you a shout...
Trek, the script is ready to cut. Fiddling with the names a bit still. I'll have it all in my suitcase when I hit the ground out there...
Anything else out of the norm I need to bring?
trekkor 05-07-2011 10:22 PM
Engine hoist... :D
KT
porsche4life 05-07-2011 11:06 PM
Don't think it will fit in my carry on.....
And this is an OK engine hoist....
http://forums.pelicanparts.com/uploa...1304834781.jpg
rusnak 05-07-2011 11:19 PM
You guys have great toys. Nice lights.
Hugh R 05-08-2011 07:06 AM
Sid, you are a smart cookie to use an intermediary between the fork blades and the strap. I had a show where someone wrapped the lifting strap over the blades and it cut it like a knife. The set piece weighted about 1,000 pounds and when the strap failed, it broke his ankles.
porsche4life 05-08-2011 07:47 AM
Hugh, we we have 3 cranes... Rigging is one thing we are good at. :D
We have since taken a big piece of tubing and cut it to the length of the forks and welded an eyelet. We now have a place to hook a clevis for straps.
trekkor 05-08-2011 06:16 PM
Any clothes or hats with 'Porsche' on it for you to wear. :)
KT
trekkor 05-08-2011 06:18 PM
http://i944.photobucket.com/albums/a...p/P1110589.jpg
http://i944.photobucket.com/albums/a...p/P1110590.jpg
KT
