I see you
Computer help please
Guys/gals,
I was online watching the NHL when I suddenly got all kinds of HDD and RAM errors. Now thhe system won't even boot up. It says RAM usage is way high and there are damaged sectors on the HD. Is it likely to be a HD crash or did I catch a virus? TIA
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
At what point does it say RAM usage is too high and damaged sectors? Not a lot of info to go off of here.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I see you
when I try to restart the unit I get the messages. Autofix doesn't work.I'm running Vista.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 05-21-2011 at 02:07 PM.. |
So you get past the BIOS screen, Vista starts to load and then error messages? If you hit F8 you get to the Vista boot menu...
If this is the case, yes, probably HD related. Do you know how to burn an ISO image to CD?
I see you
not sure what the BIOS is. I get the welcome screen then it goes straight into the diagnostics screen, all kinds of critical errors. I'm on my laptop now, the prob is in my desktop. prolly coulldn't do the burn even if I knew how. RAM temp to high, unaccesible/unreadable sectors...Apollo 13 kinda stuff.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 05-21-2011 at 02:23 PM.. |
Any way you can post a pic of the screen? I'm having a hard time visualizing the screen. Thanks.
Are the fans spinning in the PC?
Scam. Virus, "Windows Restore" maybe. Gives all kinds of error messages. Google it or look here for the thread on google images.
B
1980 911 SC targa 1959 Triumph TR3A - sold Something new is on the truck... |
I see you
![]() fan is blowing but there are several amber lights glowing that I've not noticed before inside the cabinet
I see you
Sure sounds like the google image scam. crap. is there anything I can do to clear it? I have an up to date AV but I can't get to it.
Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I see you
thanks Slodave, thanks Tim but how do I get the cleaning files onto my desktop if I cant get past the malware screen?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 05-21-2011 at 03:05 PM.. |
Navin Johnson
You might have to put the removal program on a usb stick, then start the machine in safe-mode, and run the removal tool in safe-mode..
Since you have two pcs it makes it easier to fix the infected one...
I see you
sigh...it didn't work. but I didn't run in safe mode. i put it on a usb stick, started the PC and executed it. but the malware is still there.
Did you actually run malwarebytes or just install it?
I see you
I had to run it all twice to sweep it clean, un-hide everything then I ran malwarebytes. my system is running but it still isn't quite right. the background is black and some windows files are missing. but i've had enough of IE, i want to switch to something other.
the help you guys provided was a great benefit!
