Shaun @ Tru6's Avatar
What are these electrical symbols?
With a ton of help from friends, I got the 3.2 from my old 86 into the 73 today. Install went fairly well, it turns over, but won't actually start. I think it's because of the factory alarm from the 86. While I was dismantling that car, it stopped starting after I pulled off the driver's door.
Here's the wiring for the DME relay. What do the symbols mean that connect 86 and 85?
What can I do to tell the relay that alarm is set and all is good?
Tru6 Restoration & Design
Old 06-26-2011, 04:58 PM
tangerine911S's Avatar
Looks like a resistor and inductor in parallel on the left and a switch on the right.
Old 06-26-2011, 05:02 PM
one of gods prototypes
bell's Avatar
term 85 and 86 are the coil in the relay which switch the contact term 30 and 87 together when activated.
Brought to you by Carl's Jr.
Old 06-26-2011, 05:05 PM
measure 12 volts on 86, the relay should click and there should be 12 volts on the injectors and the dme
Rick
88 Cab
Detached Member
Hugh R's Avatar
IIRC, I read here once that the key for the alarm in the door switches from one resistor to another meaning you couldn't pull the cylinder and simply jumper the wires if you wanted to steal it. I see two resistors there
Hugh
Old 06-26-2011, 05:23 PM
Thanks for the explanation on what's inside.
So should I just run the black wire to constant hot?
Old 06-26-2011, 05:30 PM
Zeke's Avatar
Shaun, search Early_S_Man for the bypass of the Carrera factory alarm.
Old 06-26-2011, 05:49 PM
Thanks Milt. I search through all posts "alarm" for Early_S_Man. THere was one great post about running connectors in the wiring block to disable the alarm, but it doesn't apply my situation as I don't have any alarm wiring save for the black wire.
Old 06-26-2011, 06:05 PM
MarKoBrow's Avatar
When 86 receives 12 volts it closes the contact between 85 and 87 to complete a circuit. In order to bypass you would short terminals 85 and 87
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 06-26-2011, 06:11 PM
dezzmo's Avatar
Shaun, it's too bad Chris had to leave so early because we could have looked at his wiring. He has an 86 motor/wiring just like yours, right?
EarlyS 1017
RGruppe 663
73 911T 3.2
01 Ducati S4 Monster 00 Ducati 996
Old 06-26-2011, 06:30 PM
yes, but his is the last wiring we want to look at.
I feel good about sorting this out tomorrow evening.
MarK, what's the best way to short these two terminals? inside the relay? I could solder a bridge I suppose.
Old 06-26-2011, 06:36 PM
UnRegistered User
billybek's Avatar
It seems strange to me why they would route a resistor in parallel with the coil for the relay. The only thing that I can think of that it may be a heater element for a thermal delay switch and those contacts are not shown.
Weird.
Bill K.
Old 06-26-2011, 06:44 PM
dezzmo's Avatar
Yeah, but at least his runs
Keep me posted tomorrow........
EarlyS 1017
RGruppe 663
73 911T 3.2
Old 06-26-2011, 07:03 PM
MarKoBrow's Avatar
I would think you can back probe the relay just to verify this the problem, I am pretty sure there is a few products that will allow you to join the wires together without cutting.
2012 Audi A8L
Old 06-26-2011, 07:57 PM
sometimes.
Will be out there at 5 today with a wire bridge for 85 and 87, that 22 gauge Toyota wiring will work well I think. might try at lunch though.
Old 06-27-2011, 04:40 AM
billh1963's Avatar
Far left is a diode...don't forget to check that.
Old 06-27-2011, 06:24 AM
crossing 85 and 87 with .025 welding wire = light bulb and disintegration.
Old 06-27-2011, 02:06 PM
Moving on to the factory DME test plan (thank you Chris Bennet), step 7: Terminal 85b should have ground if engine is started and terminals 30 and 87 were bridged on relay plug.
Well, with no relay and a jumper between 30 and 87, it started right up like I just parked it a few minutes ago. Bit loud without the S pipes and muffler, but the headers take on a wonderful hum at 2K.
With that, any ideas on what's happening? I don't think I can delete the DME relay in practice.
Going to hand the exhaust now.
Old 06-27-2011, 02:49 PM
MarKoBrow's Avatar
Hey Shaun I just looked again and it should have been 87 and 30 in the diagram 85 crosses 30 . I hope you didn't mess anything up via my bad advice? When you short 87 and 30 with the relay installed does 87 become charged with +12v or do you have to turn on key?
2012 Audi A8L
Old 06-27-2011, 03:10 PM
Nope, nothing messed up, I like to use welding wire as it makes a great fuse. I got the exhaust on and the motor runs like it's been in the car for years. So happy. Now it's details, and there are a ton of those to get the car back on the road.
Old 06-27-2011, 05:58 PM
