-   -   MAF Sensor..... help (http://forums.pelicanparts.com/off-topic-discussions/618924-maf-sensor-help.html)
PRE-H20 07-12-2011 03:45 PM
hey guys... are there any mercedes guys here?
i need to locate the MAF on a 2005 C230 Kompressor......
anyone?
here are pictures of the engine bay....... i know its in the area... just dont know what to look for or where... please point an arrow to it like you guys normally do.....
thanks....!!!
http://forums.pelicanparts.com/uploa...1310510610.jpg
http://forums.pelicanparts.com/uploa...1310510685.jpg
http://forums.pelicanparts.com/uploa...1310510700.jpg
http://forums.pelicanparts.com/uploa...1310510730.jpg
A930Rocket 07-12-2011 03:54 PM
I'm going to say this is it.
http://forums.pelicanparts.com/uploa...1310511248.jpg
Rick V 07-12-2011 03:55 PM
The "screen thingie" that the air filter was hooked to with the flat bosch connector on it. Pic one is spot on
Jared at Pelican Parts 07-12-2011 03:57 PM
The MAF sensor is in the first picture. Unscrew the sensor from the airbox.
A930Rocket 07-12-2011 03:58 PM
I wanted to confirm my post and my search found your post on MB World.
Even the pix from 2007 are the same. :)
PRE-H20 07-12-2011 04:02 PM
jared.... sorry to be a knucklehead but can you point an arrow to it.... so far there are three answers on this thread. an arrow to the MAF and the connector please.
i dont see a connector on the grill looking thingy.........
sorry guys im just a rookie on this stuff.......
PRE-H20 07-12-2011 04:04 PM
a930rocket...
yup i just posted there... i JUST signed up there..... but i dont know anyone over there.... i trust you guys here alot more... been here since 2005 or so......
my bride to be a freaking out over her car and its idling funny..... so im trying to get some info on it..... looks like i inherited a bit of a headache fellas..... RRR.
Rick V 07-12-2011 04:17 PM
Originally Posted by A930Rocket (Post 6131733)
Dewd, it doesn't get much more pointed out than right here. All 3 answers are correct
bell 07-12-2011 04:23 PM
the maff is the whole round part which air travels through......as was arrowed LOL
the plastic mesh screen is to keep debris from flying into it as they are VERY sensitive, don't get a drop of oil on it or it'll burn up.......the wire which is monitored probes down into the "tube" and connects to the plug.......
do not mess with it too much, it can't be cleaned......
A930Rocket 07-12-2011 04:34 PM
Can MAF cleaner be used? I've used it during tune ups, but not sure if it does any good.
Rick V 07-12-2011 04:37 PM
It doesn't hurt, the best thing you can do is stay from oil type of filters (K&N) and keep the paper filters changed
bell 07-12-2011 04:57 PM
i've never had any luck cleaning sensors, because once they start to fail and cause running problems the wire/sensor has already failed......
Jared at Pelican Parts 07-13-2011 08:49 AM
http://forums.pelicanparts.com/uploa...1310572142.jpg
This is the MAF sensor.
PRE-H20 07-13-2011 09:02 AM
thanks guys
thanks guys... even the smarties that have commented. much appreciated!
id rather ask some bonehead questions than take a chance and made a mistake or make things worse.
gr8fl4porsche 07-13-2011 09:21 AM
+1 for no luck cleaning.
Just replace it
Jared at Pelican Parts 07-13-2011 09:23 AM
I also think you probably won't have much luck cleaning it.
john70t 07-13-2011 12:31 PM
Just a question, but how was the determination made that it was a bad MAF?
There are a variety of things which could cause a bad idle, and the computer code only spits out what it thinks is wrong, not always what is actually causing that sensor to return data out-of-spec. For instance, there could be a vacuum leak after the manifold and the computer thinks the metered flow doesn't match the idle rpm, so it blames the MAF.
Not second guessing the situation, just putting it out there.
I'm a "parts guesser" myself so you don't want to make my mistakes..
Some high-end vehicles use a MAF and a MAP(manifold absolute pressure) sensor, I've been told. No knowledge of that model.
Jared at Pelican Parts 07-13-2011 12:58 PM
is it a surging idle, like going up and down? If so, it's a vacuum leak, not the MAF.
turbo6bar 07-13-2011 01:04 PM
Vacuum leak would also show up as a high idle.
ChemMan 07-14-2011 03:20 PM
Do you have a CEL? The MAF typically will throw P0170 and P0173. You can remove it and spray the wire with CRC Mass Air Flow Sensor Cleaner. This might fix your problem but the if the MAF is bad it should throw the codes.
