-   -   Vista installation hosed? crcdisk.sys freeze (http://forums.pelicanparts.com/off-topic-discussions/619142-vista-installation-hosed-crcdisk-sys-freeze.html)
WolfeMacleod 07-13-2011 03:04 PM
About a year ago I reinstalled Vista 64 (Ultimate) when the HDD died in this laptop = an HP dv9000. I replaced the HDD of course.
A couple months later, I started to get freesing when Vista would start to boot up. It went through POST just fine, but the instant the Status Bar and Microsoft logo would start to appear, it hung and stayed hung.
Occasionally, it would boot up.
Starting to get really, really annoying. Last week it took a couple hours or repeated trying to get it to boot.
I found during some searching that it's caused by a crcdisk.sys error of some sort, evident when trying to boot into safe mode... it hangs when it loads that file.
NO solution anywhere to be found, short of reinstalling. Which.... might not work so well, since it does the same thing when booting off the disk.
Anyone heard of this? Anyone found a fix? :confused:
Also.. the laptop frequently does not come out of hybernation/sleep mode when opening the lid...
azasadny 07-13-2011 03:13 PM
I would install the Windows 7 upgrade, it's much better than Vista... really.
WolfeMacleod 07-13-2011 03:20 PM
I did one of those "upgrades" a long time ago. it borked everything.
I'd do a clean install before I touched an upgrade disk.
LSA 07-13-2011 03:35 PM
You can't boot from the vista disk?
I would have said boot into the recovery console and disable crcdisk.sys but the recovery console apparently went the way of the dinosaur.
What happened to the Recovery Console?
this thread may have some info for you exact same problem as you described.
Windows Vista crcdisk.sys system won't boot
WolfeMacleod 07-13-2011 03:58 PM
Frequently, no... I've tried the recovery console and did the "repair" which did not work.
Also ran chkdsk
Read that thread a while back.. it didn't help.
azasadny 07-13-2011 05:42 PM
Wolfe,
You can do a "clean" install with the Windows 7 upgrade DVD. If you want me to do it for you, ship the laptop to me and I'll do it in 2 days then ship it back running better than ever!
Brando 07-13-2011 05:45 PM
Go 7...
Brian 162 07-13-2011 08:06 PM
I had the same problem. I have the same laptop (HPdv9000). It would freeze for no reason. One day it quit completly. New hard drive was changed under warranty. Now every once in a while the touch pad won't work.
slodave 07-13-2011 09:48 PM
Try this...
1) I start windows Vista from my DVD and select repair, select the command to start the console.
2) in the command prompt I go to where my windows is installed and remane ( or delete) the following files:
\windows\system32\drivers\pcmcia.sys*
\windows\system32\drivers\1394bus.sys
\windows\system32\drivers\ohci1394.sys
\windows\system32\driverstore\filerepository\pcmci a.infblablabla*
\windows\system32\driverstore\filerepository\1394. infblablabla
\windows\system32\driverstore\filerepository\sdbus .infblablabla*
\windows\inf\sdbus.inf*
\windows\inf\sdbus.PNF*
*NOTE: the file with * were NOT renamed (or delete) and it worked for me. In case Ur PC freeze again try to rename all files.
WolfeMacleod 07-14-2011 11:27 AM
Dave, I'd tried that too.
On a related note, I purchased Win7 Ultimate last night to do a fresh install.
it hangs when it gets to the Windows Loading screen, after "Loading Files"
azasadny 07-15-2011 07:24 AM
You may have an overheating problem, bad RAM, failing hard drive or other hardware issues.
Brian 162 09-05-2011 01:54 PM
Fast forward to Sep. 2nd. My H/P laptop won't turn on. 60 days out of extended warranty, mother board gone, estimate $450 to repair.
I purchased a new Toshiba with Windows 7.
I now have an H/P paperweight.
azasadny 09-05-2011 04:19 PM
Send me the HP, I'll see if I can fix it...
gr8fl4porsche 09-05-2011 04:23 PM
Buy the extended warranty on the Toshiba. Dealing with an out of warranty bad board on a Toshiba Satellite right now!
Currently arguing with them daily in hopes of getting the POS replaced out of good will.
Brian 162 09-05-2011 05:21 PM
I got 2 year extended warranty.
Art; the h/p doesn't even turn on. I push the on-off switch and the blue lights come on for a second then the unit shuts down.
gr8fl4porsche 09-05-2011 06:16 PM
Same symptoms as my Toshiba.
id10t 09-05-2011 06:24 PM
Debian -- The Universal Operating System or Main Page - Linux Mint
