Vista installation hosed? crcdisk.sys freeze
About a year ago I reinstalled Vista 64 (Ultimate) when the HDD died in this laptop = an HP dv9000. I replaced the HDD of course.
A couple months later, I started to get freesing when Vista would start to boot up. It went through POST just fine, but the instant the Status Bar and Microsoft logo would start to appear, it hung and stayed hung. Occasionally, it would boot up. Starting to get really, really annoying. Last week it took a couple hours or repeated trying to get it to boot. I found during some searching that it's caused by a crcdisk.sys error of some sort, evident when trying to boot into safe mode... it hangs when it loads that file. NO solution anywhere to be found, short of reinstalling. Which.... might not work so well, since it does the same thing when booting off the disk. Anyone heard of this? Anyone found a fix? ![]() Also.. the laptop frequently does not come out of hybernation/sleep mode when opening the lid...
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 Last edited by WolfeMacleod; 07-13-2011 at 03:10 PM.. |
19 years and 17k posts...
I would install the Windows 7 upgrade, it's much better than Vista... really.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I'd do a clean install before I touched an upgrade disk.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
You can't boot from the vista disk?
I would have said boot into the recovery console and disable crcdisk.sys but the recovery console apparently went the way of the dinosaur. What happened to the Recovery Console? this thread may have some info for you exact same problem as you described. Windows Vista crcdisk.sys system won't boot
87 944s Sold to a fellow pelican 02 911 w/ a LS3 The "GT8" 98 Dodge Viper GTS 09 Aprillia Shiver |
Also ran chkdsk Read that thread a while back.. it didn't help.
Wolfe,
You can do a "clean" install with the Windows 7 upgrade DVD. If you want me to do it for you, ship the laptop to me and I'll do it in 2 days then ship it back running better than ever!
Burn the fire.
Go 7...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Retired Member
I had the same problem. I have the same laptop (HPdv9000). It would freeze for no reason. One day it quit completly. New hard drive was changed under warranty. Now every once in a while the touch pad won't work.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Try this...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Dave, I'd tried that too.
On a related note, I purchased Win7 Ultimate last night to do a fresh install. it hangs when it gets to the Windows Loading screen, after "Loading Files"
You may have an overheating problem, bad RAM, failing hard drive or other hardware issues.
Retired Member
Fast forward to Sep. 2nd. My H/P laptop won't turn on. 60 days out of extended warranty, mother board gone, estimate $450 to repair.
I purchased a new Toshiba with Windows 7. I now have an H/P paperweight.
Send me the HP, I'll see if I can fix it...
Buy the extended warranty on the Toshiba. Dealing with an out of warranty bad board on a Toshiba Satellite right now!
Currently arguing with them daily in hopes of getting the POS replaced out of good will.
Randy '87 911 Targa '17 Macan GTS |
Retired Member
I got 2 year extended warranty.
Art; the h/p doesn't even turn on. I push the on-off switch and the blue lights come on for a second then the unit shuts down.
Same symptoms as my Toshiba.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
