Almost Banned Once
sc_rufctr's Avatar
Clean bench help.
Laminar flow clean bench.
I'm planning to build something like this. I've got some HEPA filters and aluminium tubing and plastic plug in corners for the frame.
I just have to settle on the size and whether to use plastic or glass for the sides. (solid rear rather than glass)
I was thinking of using a small toilet or bathroom extraction fan to drive the air through the filters and enclosure. (with a variable speed controller)
Mine will also have sealed fold up doors on the front to keep it clean between uses.
I would appreciate any incite on thing to consider or include.
Should I push the filtered air down from the top or from the rear? What's better?
I'm hoping the nuke guys will chime in.
Also... Is it worth getting a small air speed meter for testing??? ($20 on EvilBay)
- Peter
Old 10-06-2011, 09:14 AM
Detached Member
Hugh R's Avatar
Off the top of my head, I don't think a bathroom fan will push very much air through HEPA filters. Any specs of the filters themselves? Most use a manometer to measure pressure drop to indicate when it is time to change the filter media. How "clean" do you want? What are you putting together, a Rolex watch or a carburator?
Hugh
Old 10-06-2011, 09:40 AM
AutoBahned
RWebb's Avatar
how important is laminar flow & how laminar?
what speeds? what is your background in this stuff?
Old 10-06-2011, 01:27 PM
Senior Member
What in the world are you working on there? Hard drive repair at home?
Old 10-06-2011, 03:54 PM
abit off center
cgarr's Avatar
I need a paint booth like that!
______________________
Craig
G2Performance
Old 10-06-2011, 05:25 PM
Unregistered
sammyg2's Avatar
A clean bench is a sign of a sick mind. Oh wait, what?
Old 10-06-2011, 05:59 PM
HEPA's require decent fans with higher static pressure than what a bathroom fan will probably provide. Depending on how "clean" you want, you may need to perforate the bench deck for adequate flow-thru to avoid particle collection in the stagnation areas near the rear of the bench. I would look for some fan-filter units (FFU's) that integrate a fan and HEPA together in a common case, and then hang a couple on a frame above your workbench. Vertical down-draft hoods generally keeps things cleaner.
Old 10-06-2011, 08:22 PM
DanielDudley's Avatar
Easier to use large particle filters and vent to the outside.
Old 10-09-2011, 04:02 AM
