I'm even questioning now if we should just start from scratch. keep the lion, unicorn, and suitcase, crown too, but create a proper, professional logo that can work as separate elements and together as a crest.
Tru6 Restoration & Design |
The Unsettler
Shaun, check mail
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
The Unsettler
This is something I had him developing for a project that we killed. It's unfinished but you can see where it was going.
abides.
Did you get a file from stomachmonkey?
What I would do: 1. Scale to desired size. Trace. Export from vector to .dxf 2. Open in AutoCAD. Double check scale. 3. Use "offset" command to offset your cutlines by 30 thou 4. Draw in bridges Here's what I got after turning your jpg into a vector then into a dxf:
Graham 1984 Carrera Targa |
The Unsettler
His original AI file was not outlined fills. It was stroked overlapping paths hence his problem with using it. New file. ![]() Original AI file with preview turned off showing the vector.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 10-06-2011 at 04:06 PM.. |
abides.
Ah, cool.
I'm no illustrator expert... i use inkscape, and know only just enough to be dangerous.
You do not have permissi
I've no experience with this or other similar programs but it coverts to pixels to the CAD geometry: Raster to Vector software.
It might save a bit of time not tracing the design, and then you could then use the transparent overlay for checking/adjusting final accuracy and continuity.
Meanwhile other things are still happening. |
huge thanks to Scott (stomachmonkey) for creating the double outline for CAD cutting, it is perfect.
