Senior Member
Removing Petrified Masking Tape from a Guitar
I've got an old "lawsuit" SG-copy bass guitar that I'd like to clean up. I used masking tape to put a piece of cloth across the back to avoid belt buckle rash and now I'd like to get all that tape and tape-adhesive off. It's probably been on there for well over two decades and probably three, so this masking tape is petrified. I don't want to hurt the finish, if I can help it. What would you guys do?
I could use a heat gun. Or chemicals. I have some Omni cleaner stuff that's a gallon of fairly harsh chemicals but I'm concerned about hurting the finish. Or just soak it with a rag for a day or two and see if it just comes off.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Try WD-40
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
I'd say what you use depends on how it was originally finished...Maybe take it to somebody who works with antique furniture & ask their opinion?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Soap and warm water or naphtha. Don't let the water sit too long and if you use naphtha, test in an inconspicuous spot..
Naphtha is just a very high grade of paint thinner and a little "hot." Before that, you might try some turpentine. I like the WD 40 idea because it's basically a solvent too. Be careful if someone says GoofOff. Not real good results with that here.
Milt, naphtha is a standard cleansing solvent used in the guitar industry.
I would not recommend turpentine. Warm soap and water first.. Last edited by slodave; 11-04-2011 at 04:16 PM.. |
BTW, just get a bottle of lighter fluid, basically the same thing as naphtha and cheaper.
Why is that? Turpentine is a basic ingredient to those boutique furniture waxes that you get for fine old pieces, the ones finished with a shellac/ varnish finish. Is a guitar lacquer any less durable? I know as a former painting contractor that naptha (how are we spelling it now?) is very irritable. T is not.
I don't know if that has anything to do with it. |
Band.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I can't give you an answer, other than from what I have read. Warm soap and water first and if that doesn't do it, naphtha or lighter fluid.
Mineral spirits can also be used, but my first two suggestions are the preferred route. |
Well, just so we agree, turpentine is rather benign and won't hurt much including your skin. In fact some people have used turpentine as a skin treatment, believe it or not. I'll defer to you since I know dick about guitars. I do know something about wood and wood finishing in general, but you, have specialized in an area I haven't visited since just out of high school. That being nitro-cellulose lacquers.
Still, I think Super would be wise to find out just what the finish on the guitar is before digging into a solvent bin. Then start as gentle as possible...hell, maybe a simple automotive "cleaner wax" would do the job...
least common denominator
Vodka! Three or four over ice and you won't even notive the tape.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Now after a little more reading I will say this: If you know for sure that the finish is nitro based, do not use anything but the three things I mentioned, even Goo Gone. Warm water and soap first, if that does not work, either naphtha or zippo lighter fluid (Ronsinol). If you know the finish is poly, then Goo Gone should work, but again, test in a hidden area first! Also, do not use alcohol, acetone or WD-40. Don't listen to Sidney, as he really hasn't a clue on this and his answer really isn't an answer.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Non Compos Mentis
Hey, Super!
You've seen what I can do with a Sawzall! -Sorry about cutting through that fuel line...Whoops. |
Senior Member
I decided to try this first, only with scotch. Seems to be working.......
Senior Member
That was my bad, Dan. And the problem was solved.
Senior Member
The finish is pretty 'deep,' making me think it is lacquer. So.....Lacquer Thinner is off the list. Perhaps we'll start with warm, soapy water. If that doesn't work, I'll go back to the scotch which seems to work.
