RedBaron's Avatar
Best Source for Automotive Electrical Connectors?
I have been actively looking for an electrical connector piece for my mom's Volvo 960. The piece is a two pole black female connector for the engine block temperature sensor and is a part of the main wiring harness. My father was disconnecting the piece and it broke into several pieces. Is there any source for a new plug? I have googled and researched quite a bit trying to find this connector. I thought I should ask the brain trust. Used wiring harnesses go for $100+ on eBay for this car so that is not an option. The MALE plug is pictured below.
Thanks!
Old 12-30-2011, 10:20 AM
RETIRED
Joe Bob's Avatar
AMP Connectors/Terminals
Try these guys....
2012 ML350 3.0 Turbo Diesel
Old 12-30-2011, 10:39 AM
gt350mike's Avatar
JB's recommendation is the best route. If you don't find anything there, try Mouser or Digikey. Its a long shot but judging from the size of the pins, it should help narrow your search.
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 01-01-2012, 07:29 PM
lm6y's Avatar
If you can't find the exact connector, it might be worth a trip to the bone yard, and get a different connector. Find something waterproof, get BOTH sides, and splice it in. Or, just remove the connector altogether, and hard wire it. Just be sure to solder, and dual wall heat shrink it if you do. I've had to do this on a few of the beaters I have, but no one works on them but me, so it's not a big deal.
Not many Volvos in the yards around here, but I'll keep an eye out for ya. What year 960?
Brent
Early85 944
LM6Y Paint Code
Old 01-02-2012, 07:43 AM
