Originally Posted by rick-l View Post
Could that be a dado that stops a half inch from the front?
Sure hope not.
Old 01-17-2012, 10:06 AM
Originally Posted by BSiple View Post
Cut a section out of the middle of the shelf, then see if you can pull it loose from the sides. You will be destoying the shelf obviously, but it may prevent there from being lots of damage to the outside pieces.
Agreed, don't try to cut at the edge of the shelf, just cut the thing in half. I suspect after cutting in half, the two pieces will come out easily.
Old 01-17-2012, 10:07 AM
Why not go ahead & make two cuts an inch or more apart, take out the center piece & that will give you some wiggle room. If you want to put the shelf back together, you can use 2 or 3 metal staps screwed in from the bottom (similar to plumber's tape but ridgid) to secure all of the pieces & fill in with wood filler if you want to get rid of the cut lines.
Marv Evans
'69 911E
Old 01-17-2012, 10:16 AM
Detached Member
Hugh R's Avatar
If you use a BFH, put a piece of 2"x4" on the edge where you beat on it. That way if it shears off of dowels, you might still have a salvagable shelf.
Hugh
Old 01-17-2012, 10:37 AM
Champagne on Beer Budget
HelmetHead's Avatar
pour some water on it..it will fall right off
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 01-17-2012, 10:43 AM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
Originally Posted by gassy View Post
TMI dude.
I was going to do the same thing!
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 01-17-2012, 10:51 AM
Moses's Avatar
Maybe a tile chisel down the sides?
Old 01-17-2012, 11:15 AM
Japanese saw has a thin blade that, while slow, will not mess up the laminate.
1986 3.2 Carrera
Old 01-17-2012, 12:10 PM
Unregistered
sammyg2's Avatar
C-4. Works every time.
Old 01-17-2012, 12:28 PM
Puny Bird
Mark Henry's Avatar
It's screwed together, then plastic laminate is glued on hiding the screw holes.
Best method is the cut the shelf in half suggestion, most likely it will f-up the cabinet, but custom store fixtures are cheaper than the printer.... right?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-17-2012, 12:44 PM
DanielDudley's Avatar
Multi tool. Unless of course it is the type of shelf that slides out the front.
Old 01-17-2012, 12:57 PM
Assuming it's made of pressboard, the reason the BFH will work will be because the dowls will tear right through the shelf. Using your method, the dowls might damage the part of the desk that he wants to keep. I think the "whack the shelf" option is only recommended because the shelf will sacrifice itself in the process.
Old 01-17-2012, 01:08 PM
Band.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-17-2012, 02:39 PM
enzo1's Avatar
^^^+1
76' 911s Signature Edition
Old 01-17-2012, 02:44 PM
AutoBahned
RWebb's Avatar
Originally Posted by craigster59 View Post
bfh with a downward stroke. It'll shear the dowels and take care of that pos old printer at the same time.
best answer!
Old 01-17-2012, 03:34 PM
I see you
flatbutt's Avatar
BFH every time. Besides you gots nurses to patch you up.
Old 01-17-2012, 03:42 PM
Moses's Avatar
Originally Posted by NotaBRG View Post
So, did you whack it or what?
Pictures of the carnage?
Haven't ordered the new printer yet. Wreckage starts in about a week.
I'll probably split the shelf and see if it gets loose. If there are screws, I'll shear them off with a sawzall and scraper blade.
Old 01-18-2012, 07:57 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Tease.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 01-18-2012, 08:14 AM
