tangerine911S's Avatar
Thanks for the compliments. Here are a few pictures of my progress.
Front strap finally finished. This took a very long time. The vertical lines took the longest because so much of the metal is in contact with the file at a time and the trigger guard keeps you from following through. I also think the frame steel is harder than the mainspring housing i did previously. The file was getting dull to boot. The horizontal lines took much less time. Once done, I ended the checkering by filing down the un-checkered section so that the checkering stands proud.
I then set to work on the grips. I took the amboyna burl block and sliced it into two thin panels. I first drilled pilot holes for the bushings and countersunk them on the back to fit over the bushings. I could then start filing and sanding the grips to follow the contours of the frame and magwell. I very gld I chose to make my own because having them fit perfectly to my frame will really be the type of details that make the gun. Keep in mind once varnished, the grain on this wood will really pop. These will take more time but starting to look like grips.
Old 02-06-2012, 06:57 PM
19 years and 17k posts...
azasadny's Avatar
That is going to be beautiful!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-06-2012, 07:09 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Nice checkering work. Who's barrel are you using?
I've used Caspian slides on Glocks and 1911s. They do nice work.
I'm getting ready to start a 2011 build with a Clark barrel and EGW comp.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 02-07-2012, 07:54 PM
Barrel is a Kart. Heard very good things about them.
Old 02-08-2012, 06:24 AM
I'm really bad about updating these types of build logs but the gun is just about finished. I got the parts back from the bead blasters this morning. There are a few areas I might want to touch up though. I'm happy the way it came out.
I realized after the fact that these pictures are a little blury but they show some of the detail work.
Old 08-04-2012, 02:59 PM
Old 08-04-2012, 03:00 PM
Jim Bremner's Avatar
So NICE!
Old 08-04-2012, 04:11 PM
Rick Lee's Avatar
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 08-04-2012, 04:13 PM
azasadny's Avatar
Incredible!!!
Old 08-04-2012, 04:14 PM
lm6y's Avatar
Good Lord that's nice!
Brent
Early85 944
LM6Y Paint Code
Old 08-04-2012, 06:46 PM
"YOU CANT RACE A CAB."
ODDJOB UNO's Avatar
sum of a beattch.................thats beautiful. nice work.
i think yer gonna enjoy that alot.
happy spooning.
if there are TROUT..........there are BEARS!
Old 08-04-2012, 07:54 PM
Can I be rude and ask how much $$$ your into it and how many hours?
Old 08-04-2012, 09:38 PM
Bill Douglas's Avatar
Excellent timing Sir. Please see The great PelicanParts shootout.
Old 08-04-2012, 10:56 PM
Almost Banned Once
sc_rufctr's Avatar
happy spooning.
Well said... Extrodinary! Do you do paid work like this for other people?
- Peter
Old 08-04-2012, 11:29 PM
You can read in the first few posts that I royally screwed up my first slide. That certainly added to the cost but ignoring that, I think the total is around $1300-$1400. I bought the best parts I could find so one could do it for a bit less.
I'd have a hard time guessing at how many hours I have into it. I picked up the frame and slide around Christmas of last year. A lot of the work is really slow going like the checkering and fitting the barrel and barrel bushing so I could not work n it for too long in one sitting. I also took some time off until I found some motivation to continue. If you are quick, it might take you a few weeks to a couple months.
Old 08-05-2012, 07:17 AM
I have never done anything like this before. Its my first 1911. I like to try my hand at everything. I love projects, especially challenging ones!
Old 08-05-2012, 07:18 AM
I like that bead blasted look Brian. It really evens up the lustre. Well done.
Old 08-05-2012, 01:35 PM
Thanks, Bill. I think it turned out really well. I told the guy I wanted it as fine as possible that would cover my sanding marks and I imagine this was about as fine as you can go. The glass bead media I found in some crevices was like powder. I went with stainless bead blasted finish because I wanted the option to change something or touch up the finish quickly and cheaply.
Old 08-05-2012, 03:58 PM
Very well executed - thanks for sharing!
Old 08-05-2012, 05:49 PM
