Bollweevil
There oughta be a law
Just another one of those little annoyances of life:
Cleaning out a closet I came across a heavy cardboard box with 22 AC adaptors in it with a veritable snakepit of tangled wires and jacks. Output voltages from 2.5 to 12V, amps from 300 ma to 1 amp, most DC but some AC output and several types of jacks. The common denominator? Besides all of them being made in Taiwan or China, I haven't a clue what any of them go to. Most likely whatever toy or device, etc. they went with was tossed long ago. There oughta be a law requiring manufacturers to label AC adaptors with the name of the device/toy/etc. they go to. Rant over.
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
Detached Member
I'd prefer one standardized charger, like wall plugs
Hugh |
Yeah it is pretty annoying. Some manufactures put their name on the power converter, which is nice, unless you have multiple gadgets made by the same company...
Dustin |
78 in a '71
Hugh! The smartest guy in the room!
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
Or at least standardize the voltage and polarity of each plug size, so any size "1" charger would work in size "1" devices. Then you could have various standardized chargers in each voltage.
Neil '73 911S targa |
19 years and 17k posts...
Yes, very annoying! I especially hate the huge AC adapters that take up two or three spots on a strip outlet.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Senior Member
One charger is not going to work. Some batteries/devices run on 1.5V, others run 3.7V, etc. Part of the reason the chargers/AC adapters are unique to a particular device is so you cannot plug a 3.7V, 1-amp charger into a device that's supposed to get .7V at .15 amps.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Gon fix it with me hammer
they could have the devices do the final bit of voltage drop internally.. it's not like it matters where they drop it.. and if they only need 1-5 volt drop, there is no big equipment needed, just a resistor
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Detached Member
Most chargers now work 110v or 220v at either 50 or 60 hz automatically, why not automatic load as well?
Hugh |
Hey this reads like a business opportunity.
Wish I knew how to run with it. |
Hugh's spot on. They should do that to cell phones and other devices that are used daily. Pass a law on that.
Bollweevil
As far as cell phones go, ANSI should jump on that one. There definitely should be a standard charger connection/jack for cell phones. As the same cell phones are used world wide that is pretty much not gonna happen unfortunately.
canna change law physics
Exactly! Lots of devices run on different voltages and have different current needs.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
This is the output. It is pretty easy to put a clipping circuit in which holds the voltage at 110VAC for the input side of the power supply. The better idea would be to require most of the devices that are never intended to run solely on DC to have an AC input and the AC to DC converter built into the device.
Senior Member
Credit where credit is due...
Seems like everything that hooks up to a USB runs on the same requirements. Isn't that a start to standardization? Freakin' laptop chargers piss me off. When one gets messed up it costs way too much to replace it.
However, I don't know what we have more of, extra power supplies or things that are missing a supply. Have to get them all out on the table and marry them up. Or sch!tcan all of it. |
Bollweevil
At our house, once the device is done, the charge goes into the trash immediately.
