-   -   3d Modeling Question (http://forums.pelicanparts.com/off-topic-discussions/655405-3d-modeling-question.html)
gtc 02-02-2012 07:44 PM
Ok... i know there are a few engineer/designer types out there with 3d modeling experience.
How do I drill radial holes in a round/spherical part? Like if I wanted to model a wiffleball? I don't remember ever doing something like this in school, and I can't find any relevant tutorials or forum posts.
FWIW I'm using Inventor, but I'm guessing it's probably a similar operation in Solidworks or whatever else is out there these days.
stomachmonkey 02-02-2012 08:05 PM
https://encrypted-tbn2.google.com/im...5HTdjVhWSEnGqA
Bump
HardDrive 02-02-2012 09:49 PM
Does this help?
Create a Tapped Hole - WikiHelp
fanaudical 02-02-2012 10:05 PM
My "generic" approach for a line of radial holes around the equator of a sphere:
- Revolve a couple of concentric arcs about an axis. This creates the shell of the sphere.
- "Extrude cut" a hole from the center of the axis "through all" the entire sphere.
- Rotary pattern the extrusion about the axis.
A true wiffleball will require a CAD tool with surface topology pattern capability. I don't believe that's Inventor...
Flieger 02-02-2012 10:36 PM
Might be able to do something with the sheet metal or warp functions. It depends on the hole. Otherwise I would setup a plane and a couple axis, extrude cut a hole through the spherical shell, then rotary pattern it about several axes.
island911 02-02-2012 10:50 PM
The pitch will be different, at different "latitudes" - so you'll need to create a few circular patterns.
make a hemisphere and mirror
IROC 02-03-2012 04:41 AM
+1. This is how I would do it in ProE.
David 02-03-2012 09:34 AM
In Inventor, place a work plane on the cylinder or sphere, sketch a circle on the plane and extrude a hole.
gtc 02-03-2012 09:38 AM
Thanks for the tips, I'll give them a shot.
