AutoBahned
USB HighSpeed
I frequently get a notation that "this device could perform faster if you use it on a HighSpeed USB port" or some such.
But how do I find out which ports are high speed USB? This is on a Win 7 machine with quite a few USB ports scattered all over the place... |
Almost Banned Once
Are they colour coded? (plastic tag inside the socket) In know the new Lenovo Stinkpads are.
- Peter |
AutoBahned
no, they all seem to white inside
is there any way to run a software app to test them? |
Used Up User
From Wiki USB3.0 : "There have been many reports of USB 3.0 equipment only transferring data at USB 2.0 speed, usually with a message "This USB Mass Storage Device can transfer information faster if you connect it to a Super-Speed USB 3.0 port". This has been due to several causes, including drivers, certain cables specified as USB 3.0 (problems disappeared when a different cable was used), order of starting equipment, equipment needing to be disconnected and reconnected, and overclocked computers."
Other than speed, the dual-directional data transfer allows use of an asynchronous USB D to A. This solves the problem of dueling DAC clocks which has plagued earlier USB DACs for high quality audio applications. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
AutoBahned
interesting - I did not think the device was 3.0 but...
Banned
I wish Apple would go to USB 3 Instead they adopt some lame ass thunderbolt. Asshats.
AutoBahned
for some reason there are "Enhanced" ones - high speed and (maybe) non-highspeed ones -- is that what this means?
![]() or does it just have the "Standard OPenHCD" ones for compatibility or something? |
