Converting a 900cc Ducati engine to a single, how hard?
If I bought a carbed 900cc Ducati engine, how hard would it be to convert it to a single? I'm guess not that hard, since I drove my 900SS with a fouled plug on one cylinder, and it ran.....with admittedly less power.....
Could it be as simple as removing the piston, sealing off the case, and removing the wiring for the missing cylinder? |
No answer whatsoever. But, why (short of the obvious less power)?
It would probably run smother if it were properly balanced to run on one cylinder...
Ducati already did that (sort of) quite some time ago.
http://www.sigmaperformance.com/mono18big.jpg The Supermono is a gorgeous bike. http://2.bp.blogspot.com/-b468uvCIA2...25281%2529.jpg I have an old 450 single ... i wouldn't describe it as 'smooth'. Although a rebuild is probably due. |
That is a nice looking machine.
was more than one ever made? I hope not as the possibility of owning one would haunt me.
http://www.enfieldmotorcycles.com/fo...07_6_04_12.JPG |
I would think it would vibrate terribly. The crank is balanced for two pistons.
Les |
I have a buddy that made a single out of a new Ducati 1098. Remove hardware, fab block off plate, re-balance crank (the tricky part). It can certainly be done.
Good God, why would you?
oh man...wikipedia has total supermono production run of 65...
Nothing greater.
---Vincent H.R.D did it many years ago, I worked with a guy had a Vincent 'Comet"---500cc
single. The rear barrel was removed and a blanking plate on the case. I dont know what they did inside. I travelled pillion on it daily for some months, [1959/60]---- Well I guess my memory is fading---I recalled 'Google is your friend' and came up with this---------- How the legendary Vincent Rapide V-Twin engine was concieved is certainly one of the most tantalizing legends in all of Classic British Motorcycle-dom. Phil Irving was sitting at the drawing board one day with two tracings of the 500cc single. As things got moved around, the top tracing roughly lined up with the bottom one (identical to the top) at such an angle as to look like a V-twin. With a little cajoling, he lined up the crankshaft centerlines & the timing idler gears & ended up with a 47.5 degree V-twin. The single you see, was canted forward at 23.75 degrees, so this just duplicated that angle to the rear. In doing so, the 1936 Series A Vincent Rapide was born. The 994cc V-twin had 6.8:1 compression, made 45 hp & was good for 110 mph. Absolutely stellar performance in 1936! The Series A (or first generation) engine was somewhat crude when compared with later models, with its non-unit construction & exterior oil lines. The clutch & transmission was also weak. But the Vincent Rapide was still a stunning success for the tiny Vincent-HRD Motorcycle Co. It had a brazed lug frame with Vincent’s patented cantilever rear suspension & a girder front end. |
Here's a story about a fellow who did just that with his 748.
Ductalk Again, what could possibly be so great about an Enfield Bullet frame that would make a grown-up person want to do that? d. |
This guy did it with a HD motor...and built a beauty of a ride doing it!
Nortorious by Roger Goldammer |
SuperMono, yummmm. Last I heard they were going for around $75K a pop. I saw a guy at California Speedway tracking one once. Respekt!
| All times are GMT -8. The time now is 01:22 PM. |
