AutoBahned
RWebb's Avatar
How Bad is this Plumbing & Electrical wire snarl??
Top:
Just below that is this:
What - if anything - should I do to it before I seal it up again?
I can move that elec. line over a bit to the left -- it seems odd to me to have water lines near electricity... (of course Porsche ran electric wires near the gas lines on my car).
Old 03-06-2012, 12:05 PM
AutoBahned
RWebb's Avatar
BTW - my plan is to tap into the hot water line for a shorter run to the kitchen, as shown in red:
Old 03-06-2012, 12:07 PM
Used Up User
imcarthur's Avatar
Shorten that electrical wire & secure it to the stud with a staple. Usually by code they want it secured within about 12" of an electrical box iirc.
Ian
'87 Carrera Cab
Old 03-06-2012, 12:17 PM
Ian
Just wrap it around the copper pipe several times. That'll shorten and secure it!
Just kidding!
Old 03-06-2012, 01:14 PM
Friend of Warren
What does the other end of that wire go to. Almost looks as if it was designed to be pulled up through the floor. For example is it connected to a dishwasher and you need that much slack when you pull the dishwasher out from its cabinet?
Kurt V
Old 03-06-2012, 01:18 PM
NO. it doesn't work like that with the dishwasher. Do not ever do that. If you need slack, the slack should be in front of the wall, never behind.
the line coming out of the wall feeds the box it looks like. Like Imcarthur said, shove the wire through and staple to the stud within 12" to the box. As least that code around here.
Old 03-06-2012, 01:39 PM
AutoBahned
RWebb's Avatar
thx
the wire goes to a wall light fixture in the bathroom on the other side
Old 03-06-2012, 04:20 PM
While it's open, you may wish to put metal nailing plates over the cut-outs in the 2X4's where the pipes pass through. The other pictures are a bit dark but it looks like there may be a couple of cut-outs there as well. Nothing worse than driving a drywall screw or picture nail through a water pipe in the wall.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-06-2012, 04:51 PM
AutoBahned
RWebb's Avatar
thx - that's a good idea
Old 03-06-2012, 05:24 PM
Slackerous Maximus
HardDrive's Avatar
That does not remotely qualify as a 'snarl' in my book. I've found things in my own home that seem to defy the laws of physics.
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 03-06-2012, 07:55 PM
GWN7's Avatar
Put a protector plate over where the waste pipe goes thru the stud also. If those leak it can be worse than a water line.
Bunch of old cars
Old 03-06-2012, 09:54 PM
