winter-hater club member
nynor's Avatar
my stainless cooking pans are sticky
i am tired of eggs and meat sticking to my stainless cookware. is there anything i can do to solve this problem?
"COOL PRIUS!" - Nobody Ever
Old 04-01-2012, 07:22 PM
Well are you scrubbing them bare after cooking or do they just get a soap and water hand wash but keeping some of their "oiliness?"
Old 04-01-2012, 07:32 PM
nynor's Avatar
hand washed, but very thoroughly, because anytime i try to cook eggs or meat, it sticks like mad to the pan. i tried seasoning them by baking them at low heat with some oil rubbed onto the cooking surface. no good. everything stuck and i had to scrub them raw.
Old 04-01-2012, 07:45 PM
nynor's Avatar
do i need to polish the cooking surface? have i missed some sort of surface prep?
madmmac's Avatar
Make sure the pan is heated to your desired cooking temp prior to adding the food....or Pam.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 04-01-2012, 08:35 PM
jyl jyl is online now
jyl's Avatar
Cooking proteins stick to stainless steel. You can make it manageable, though.
1. Keep the cooking surface clean and smooth. About 1X year, I take the drill, buffing pad, and metal polish and get the pan super-smooth. The difference is amazing.
2. Use moderate temperatures. At high heat, everything sticks to stainless and even some oils (e.g. olive, sesame, Pam) will form a stubborn brown coating.
3. Use enough oil. Oil or other fat (lard, butter, animal fat) reduces sticking. Don't worry about the health aspects. Two teaspoons of olive oil in the pan - maybe half a teaspoon gets onto your plate, and it's good for you.
4. Let the protein cook enough to unstick. If you place a pork chop in a stainless steel pan on high heat, it will stick right away. Let it keep cooking, and the meat will get brown and crusty, and then will unstick or release. You'll be able to shake the pan or prod the meat, and move it. Eggs are not as cooperative.
So, do all those things: buff the pan, use plenty of oil, more moderate heat, be patient. It will work out.
I do use cast iron for high heat searing, for this very reason.
Old 04-01-2012, 08:38 PM
vash's Avatar
Barkeeper friend
poof! gone
Old 04-01-2012, 09:02 PM
nynor's Avatar
okay, polish the pan. what do i use?
Old 04-01-2012, 09:06 PM
jyl's Avatar
Whatever metal polish is around. Wash the pan very thoroughly afterwards, of course.
Old 04-01-2012, 10:01 PM
Slackerous Maximus
HardDrive's Avatar
barkeeper friend
+1
2014 Cayman S, PDK
Old 04-01-2012, 10:04 PM
Slackerous Maximus
HardDrive's Avatar
Bar Keepers Friend | Cleaning Products | Household Cleaning Supplies
2014 Cayman S, PDK
Old 04-01-2012, 10:06 PM
rnln's Avatar
Can I use metal wheel polish? and buff?
Can I use dish washer saop to wash it? I mean, does dish washer is strong enough to wash away all the wheel polish compound? I don't want to have any of those stuff in our stomach.
Fat butt 911, 1987
Old 04-02-2012, 01:47 AM
jyl's Avatar
I once wondered about the safety of polishing compounds and cleaning compounds, used on cookware. I and a friend looked up MSDS for various products. Twinkle, Bar Keep Friend, Wenol, etc. My conclusion was they seemed generally bad to eat in meaningful quantities or to put in your eyes, but didn't seem dangerous enough that I was going to worry about the micrograms that might be left in the pores of the steel after buffing and washing. You have to decide how cautious you want to be. My logic is: everything has a dose-response, if the dose is extremely minuscule, I am not super worried about the response.
Old 04-02-2012, 04:49 AM
vash's Avatar
A SS Pam is a searing machine. The fact that food sticks is a beauty when it comes to building a pan sauce. I don't think you are using the right tool for eggs and delicate foods. Nonstick wears out so I keep buying alum pans from a restaurant supply store. About $20. I keep a 8 inch and 12 inch handy at all times.
poof! gone
Old 04-02-2012, 07:00 AM
19 years and 17k posts...
azasadny's Avatar
I clean them with Krud Kutter or Barkeeper's Friend and Beth uses a little olive oil when using the All Clad cookware...
Old 04-02-2012, 07:16 AM
Takin' hard left turns
Amail's Avatar
We've gone thru a lot of cookware at home. Nothing beats cast iron. It's cheap, it's durable, and when properly seasoned, food doesn't stick. Your grandkids will pass it on to their grandkids. Keep your stainless for show, but use the cast iron for go.
This one is about $25 from Amazon, and it's fantastic.
Lodge Logic L10SK3 12-Inch Pre-Seasoned Skillet
Old 04-02-2012, 09:44 AM
Senior Member
Superman's Avatar
All my frying pans are stainless or cast iron. For most frying purposes, I use the cast iron.
Mocha 1978 911SC. "Coco"
Old 04-02-2012, 10:07 AM
Detached Member
Hugh R's Avatar
Barkeepers and PAM
Hugh
Old 04-02-2012, 11:08 AM
Zeke's Avatar
Cast iron is good stuff, no doubt, but not everyone can handle the weight. We don't use what CI we have and we have one of everything and 2 of some.
All cookware benefits from a quick boil of some water to loosen crust after cooking. If you do this to CI, you have to wipe it dry and reoil while warm. It won't really un-season the pan, but it's not the same as just wiping out. For all the others, boil away.
Old 04-02-2012, 11:40 AM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
there's your problem. never heard of stainless being non-stick.
CAST IRON will become non-stick but it takes time and seasoning and care.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 04-02-2012, 11:52 AM
