-   -   coolant question (http://forums.pelicanparts.com/off-topic-discussions/681972-coolant-question.html)
look 171 06-05-2012 07:30 PM
coolant question
My father's little Honda finally had a leak on the upper rad. hose. Funny thing is, the coolant that dripped out onto the ground and the tranny dries to a crust. What does that mean? Coolant was changed about 30k miles ago. I have never seen that before. it looks like green battery acid but washes right off with a garden hose.
Mrmerlin 06-05-2012 07:47 PM
it might be a good idea to swap out the coolant,
also pay close attention to the radiator edge seal,
if it has plastic tanks then it may also be leaking along the seal.
What your seeing is the heavy ends staying behind as the water part of the coolant mixture evaporates.
It might also be a good idea to swap out the thermostat,
use distilled water found at the supermarket to mix with your new coolant
Bill Douglas 06-05-2012 09:16 PM
If it leaks onto the ground cats and dogs lick it up and later die of kidney failure.
dhoward 06-05-2012 09:36 PM
.....at which time they can be converted into flying machines.
nzporsche944s2 06-06-2012 03:12 AM
^^ nice cross thread reference!
