coolant question
My father's little Honda finally had a leak on the upper rad. hose. Funny thing is, the coolant that dripped out onto the ground and the tranny dries to a crust. What does that mean? Coolant was changed about 30k miles ago. I have never seen that before. it looks like green battery acid but washes right off with a garden hose.
Petie3rd
it might be a good idea to swap out the coolant,
also pay close attention to the radiator edge seal, if it has plastic tanks then it may also be leaking along the seal. What your seeing is the heavy ends staying behind as the water part of the coolant mixture evaporates. It might also be a good idea to swap out the thermostat, use distilled water found at the supermarket to mix with your new coolant
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
If it leaks onto the ground cats and dogs lick it up and later die of kidney failure.
Unoffended by naked girls
.....at which time they can be converted into flying machines.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
^^ nice cross thread reference!
