vash's Avatar
good lord..coordinating my GPS to USGS maps is giving me fits!!
i think i am getting it..but man, what a trek!!
i want to have paper maps with me in the wilderness, and fire up the GPS occasionally to locate myself.
i switched my unit to UTM-UPS..and the datum to NAD 27 CONUS..now what?
i guess i need a map of my current position to learn this..i only have maps of other places.
any tips for a dummy?
poof! gone
Old 06-08-2012, 10:41 PM
JW Apostate
trekkor's Avatar
Garsh...
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 06-08-2012, 10:49 PM
lm6y's Avatar
Draw out your grid lines, and get one of these.
UTM / MGRS Tools
Brent
Early85 944
LM6Y Paint Code
Old 06-09-2012, 09:26 AM
vash's Avatar
thanks!!! that booklet they sell looks great!! maybe i will hit the local book store too.
thanks for the idea, brent.
poof! gone
Old 06-09-2012, 11:56 AM
lm6y's Avatar
No problem! I've actually used the grid tool. It takes a bit to get comfortable using it, but once you do, it's second nature.
Brent
Early85 944
LM6Y Paint Code
Old 06-09-2012, 04:57 PM
vash's Avatar
they sell that grid thing at REI.
i just ordered six books from my local library. i am all over this.
poof! gone
Old 06-10-2012, 09:10 PM
NAD 27 Conus is a very old (1927) datum. There are a lot of errors in it. NAD 83 is much better but you have to work with what you have.
Old 06-11-2012, 05:58 AM
I am not a surveyor so I know my limits of knowledge. UTM="Universal Transverse Mercator" and UPS="Universal Polar Stereographic" Just because I am curious why are you using UPS? That is to map the polar regions.
Old 06-11-2012, 06:06 AM
vash's Avatar
honestly..i dont know.
i just figured out the acronyms the other night. here is what i do know. i have a few topo maps. in the lower corners, it shows the units and datum. i have to set my GPS to those same parameters. that way, i only need to power up the GPS, get the coords of my current location..and find myself on a paper map.
i think a limitation to downloaded maps is the tiny screen. i see myself no problemo..but i cant scroll out to see a nice ridgeline, with a basin and timber growth..
just trying to use my GPS to the fullest.
poof! gone
Old 06-11-2012, 08:06 AM
Just guessing but I would suspect those paper maps are either in WGS84 or UTM NAD27 Zone10 (or Zone 11 if you are in Southern Cal.)
One of the mapping programs we use can re-project a digital map. It is crazy how many different projections are available. I always wanted to make a map in datum like Interplanetary, Jupiter, or Beijing 1954.
Old 06-11-2012, 08:17 AM
LakeCleElum's Avatar
I volunteer with the local Search & Rescue. We've recently switched from NAD 27 to Utm CODES.....If someone is lost/hurt and call in their Lat/Long, I can sit at the computer in the Command post and convert it.
There are new standards coming out for SAR, all switching to UTM is just a matter of time...
What I do when out snowmobiling and dirt biking, is mark my points on the GPS at times and give them names I'll remember. Example, We have a hard to find local "secret trail" to drop into a canyon. I just marked the spot and named it: "Drop over the side". G'luck.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-11-2012, 08:35 AM
Hilbilly Deluxe
emcon5's Avatar
GPS? Pussy.
Military Prismatic Sighting Compass w/ Pouch: Amazon.com: Sports & Outdoors
82 911SC Coupe
GTI Cup #43
Old 06-11-2012, 09:09 AM
id10t's Avatar
Yes, while a real compass is needed, they really don't help much with locating where you are at when you are in flat, brushy terrain... like most of Florida. In mountainous areas, they do help, since you can actually get stable points of reference that you can see above the tree/brush line
Old 06-11-2012, 09:27 AM
Hilbilly Deluxe
emcon5's Avatar
I actually learned to use it in Florida.
82 911SC Coupe
GTI Cup #43
Old 06-11-2012, 09:52 AM
AutoBahned
RWebb's Avatar
older maps are harder to use with a GPS as they lack some of the annotations that more modern ones have
not sure I recall all this as it has been a loooong time... but one thing is to locate your basic (coarse) location -- then go to the SW corner of that box (lower LH) and use the Northing and Easting to dial it in
you can change the GPS unit to match UTM or whatever is on your map
Old 06-11-2012, 02:26 PM
