scottbombedout's Avatar
500cc chemical release into air...
Right, todays question
If 500cc of a chemical was released into the air and it was evenly distributed in a concentration of 10 PPM up to a height of 2 meters, how far would it potentially contaminate?
Scott
88 carrera
Using the teutonic shift method since 1990.
Old 06-16-2012, 12:35 PM
AutoBahned
RWebb's Avatar
what is the wind profile
AND, define "contaminate" - is one molecule included
since you said "chemical" and not "biological warfare agent" I guess we are pretty safe over here in the US...
Old 06-16-2012, 12:48 PM
Banned
PURE 500CC X 1,000,000 = 500 MILLION CC /10 =50 MILLION CC OF AIR
wind defines where it goes
but volume is unaffected by direction
Old 06-16-2012, 12:54 PM
Definitely chemical and I mention 10 ppm because that is the level before you smell it and know its there.
Curse you adding in wind profile
Lets just say if the chemical could be evenly distributed (but to a height of 2 meters), what area could be covered?
Oh and humming birds are excluded from the area
88 carrera
Old 06-16-2012, 12:56 PM
Max Sluiter
Flieger's Avatar
Are we to assume the ground is perfectly flat?
Old 06-16-2012, 01:26 PM
Senior Member
Superman's Avatar
Is this an African chemical, or European?
Mocha 1978 911SC. "Coco"
Old 06-16-2012, 01:29 PM
Perfectly flat. I think I have an answer but it seems too small.
88 carrera
Old 06-16-2012, 01:34 PM
FUSHIGI
and if this chemical drifted through...a shrubbery....?
Old 06-16-2012, 01:52 PM
Ok, I surrender.
88 carrera
Old 06-16-2012, 02:04 PM
Non Compos Mentis
Originally Posted by scottbombedout View Post
Ok, I surrender.
Giving up already, aye?
Come back and get what's coming to ya!
Old 06-16-2012, 02:20 PM
FUSHIGI
Ok, I surrender.
Ok. We'll call it a draw.
Old 06-16-2012, 02:22 PM
I'm with Bill
Rick V's Avatar
Do we need a scale and humming bird in a box?
Old 06-16-2012, 02:23 PM
Not you too Rick? Lousy ....
Any chance a mod could delete this thread?
88 carrera
Old 06-16-2012, 02:27 PM
I'm with Bill
Rick V's Avatar
Nerd.
Old 06-16-2012, 02:34 PM
Left the room, aint coming back
88 carrera
Old 06-16-2012, 02:35 PM
FUSHIGI
Yellow!!!
Old 06-16-2012, 02:36 PM
Sultan of Sawzall
rouxroux's Avatar
I fart in your general direction (how's THAT for dispersion)?
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 06-16-2012, 03:00 PM
AutoBahned
RWebb's Avatar
here is a simple start, assuming laminar flow
if not laminar the I suggest you use eddy correlation techniques, just like us micro-climatologists do
And.... it can contaminate an area al levels lower than you can smell.
or... you may be able to smell it at levels lower than will contaminate an area...
or... it could have synergistic interaction effects with other chemicals present in some areas but not in others... or...
Old 06-16-2012, 03:02 PM
AutoBahned
RWebb's Avatar
or we could just use 10 ppm as the contamination level, assume a simple diffusion model and solve for the steady-state value
I have not (had) to do that since I was the single forlorn biology graduate student stuck in a classroom full of math grad. students in a math course on "Muddling Natural Systems."
Old 06-16-2012, 03:04 PM
19 years and 17k posts...
azasadny's Avatar
The solution to pollution is dilution... that's all I know...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-16-2012, 06:41 PM
