1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Any sure fire solution to wet electronic devices out there
I took a spill in the kayak over the weekend and got my iphone and a digital camera wet. They were in a wet bag that wasn't 100% successful. The iphone was due to be replaced anyway but I'd like to save the camera. Someone suggested a bag of rice. Is there something else you've tried with some success?
TIA.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-02-2012, 06:39 PM
Geoz1's Avatar
Open all doors that can be opened, and set it on top of the water heater for a few days.
Old 07-02-2012, 06:46 PM
canna change law physics
red-beard's Avatar
TIA.
Damp rid will work better than rice. Get a gallon plastic bag, put the damp rid canister in the bag on one side, and the electronics (with everything open) on the other side. Pull battery out if possible. Place in sunlight or WARM (not hot) place.
James
Red-beard for President, 2020
Old 07-02-2012, 07:25 PM
Cars & Coffee Killer
legion's Avatar
Silica gel will work two. You can buy it at any hobby store. Get the beads instead of the powder.
1) Make sure the device is off.
2) Remove the battery. Leave the back open. Place in a ziplock bag full of silica gel.
3) Let sit for 24+ hours.
5 liters of VVT fury now
-Chris
Old 07-02-2012, 07:33 PM
carbon tetrachloride if it's still available.
Old 07-02-2012, 08:01 PM
vacuum chamber
Rick
88 Cab
Old 07-02-2012, 08:04 PM
Banned
I dropped my iphone in a cup of coffee. It freaked out and went dead. I cleaned off the obvious fluid with paper towel (got up into the ports as well). I put it on its side, and let a hair dryer(on the cool setting) blow up into the ports for about an hour. It came back to life.
Old 07-02-2012, 08:09 PM
The Unsettler
stomachmonkey's Avatar
Rice works, leave in the bag a couple of days.
"I want my two dollars"
"Brandon Won"
Old 07-02-2012, 08:26 PM
Student of the obvious
LeeH's Avatar
I think it's a matter of luck. I lost a Motorola flip phone that went completely dead after getting lightly splashed on a ride at Disney. A year later I dropped the same model phone in a river in Oregon. I could see it all lit up leaning against a rock in over a foot of water. I fished it out, took off the battery and let it sit on the dash of the car for the rest of the day. Later that night I powered it up and it was fine.
Lee
Old 07-02-2012, 09:03 PM
AutoBahned
RWebb's Avatar
yes, but that was in Oregon water -- it seems his dropped into Cali water
Old 07-02-2012, 09:06 PM
1.367m later
KevinP73's Avatar
Better than just water, salt water. I was in the Pacific Ocean,
Old 07-02-2012, 09:38 PM
AutoBahned
RWebb's Avatar
I was afraid of that -- it is probably hosed, but drop it into fresh water - distilled maybe. Then try the above ideas.
Old 07-02-2012, 09:54 PM
1966 - 912 - SOLD
lane912's Avatar
isopropal displaces the water then evaporates-
i was too tired to be pretty last night!
Old 07-02-2012, 10:12 PM
UnRegistered User
billybek's Avatar
Originally Posted by rick-l View Post
vacuum chamber
This!
Works well, but if it was salt water you may have more problems.
I have one at work that dries out peoples electronics every once and a while.
Bill K.
Old 07-03-2012, 01:48 AM
strath44's Avatar
Is the problem more not from shorting and circuit damage if it is on / turned on whilst wet.....
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 07-03-2012, 01:56 AM
Might be too late, but here's how to save an electronic device dropped in water:
  • Remove the battery immediately, if possible, while still submerged.
  • Do not let the device dry out immediately. This causes the deposit of mineral salts on the circuit bourds, leading to short circuits later.
  • If submerged in salt water, place in fresh water for a fe minutes, to help dilute the salt content.
  • Place device in a bath of methylated spirits or isopropyl alcohol.
  • Remove after a few minutes and let it dry naturally.
Good luck!
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Kantry Member
oldE's Avatar
Good luck!
This, but after rinsing, instead of the alcohol, you can place it in a room with a dehumidifier for 24 hours.
A friend used to have a cleaning service in which they would place electronic devices in hydro sonic water tanks, then just drain and place in the dehumidifier room. Just don't power up until completely dry.
Best
Les
Best
Les
Old 07-03-2012, 03:04 AM
Best
Les
Les is absolutely right, however I would then suggest you use distilled water (as they would typically use in a hydro sonic bath) to get as much of the mineral content induced by dunking removed as possible. Water itself is not the enemy - the salts and minerals left behind after evaporation is.
Old 07-03-2012, 03:15 AM
Thread Killer
Teutonics's Avatar
Too late for this incident, but I'm considering either Liquipel or HzO waterproofing for my next iPhone upgrade.
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 07-03-2012, 07:19 AM
red-beard's Avatar
Guys, a ziplock bag works fine!
James
Old 07-03-2012, 07:28 AM
