Scott R's Avatar
Air compressor maintenance
I have a Devilbliss 90 gallon compressor, 208v electric drive to piston commercial type compressor. It's been faithful for the last ten years of heavy use and I want to keep it that way.
My question is that it's getting a bit loud, and I have some evidence of oil leaking from the piston head to air line connections. This would seem to be "maintenance" type stuff to me?
Should I call a local place that services compressors to come out and service it? Or is this a DIY type thing that anyone can tackle?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-20-2012, 08:30 AM
Senior Member
They are not hard to service.
Also make sure you drain the tank on a regular basis. Water builds up in there and its not good...
Old 08-20-2012, 08:53 AM
Scott R's Avatar
I discharge and drain at the beginning of each summer, it's very dry here in Colorado so thankfully I don't get a lot of water in the tank.
Maybe I can order and replace the various seals for the pipes, change the oil, and replace the belt and be done with it?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-20-2012, 09:38 AM
