canna change law physics
red-beard's Avatar
Ar-10
Really really want!
I've been looking over the specs and I really like the Armalite version with 7075-T6 forged reciever. A lot of the cheaper guys are using 6061-T6, which is a fine material, but about 3/5ths the strength.
Are there any other manufacturers to consider?
James
Red-beard for President, 2020
Old 09-18-2012, 07:13 AM
B58/732
BlueSkyJaunte's Avatar
CMMG/DPMS/Knights/Others. Probably the most common lower out there (there is no standard for the .308 AR like there is for the AR-15). Magpul mags are under $20 and there are a wide variety of uppers that fit.
The Armalites use M14 mags. Wouldn't you rather be hunting for targets rather than magazines?
There are hundreds, if not thousands, of cheap-ass AR15 lowers out there that are holding up to the recoil of a .50BMG upper with no problems. IMHO the alloy used is just a gimmck.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-18-2012, 07:28 AM
red-beard's Avatar
CMMG guys are using 6061-T6 for the reciever, which is cheaper and lower strength.
DPMS uses extruded 7029-T6 which is closer to 7075, but still less strong. They also do not forge the billet.
Knights must be made out of platinum! They want almost $5K for one!
James
Old 09-18-2012, 07:57 AM
id10t's Avatar
Look at the RRA LAR-8 - takes cheap and readily available FAL mags
Old 09-18-2012, 07:59 AM
winter-hater club member
nynor's Avatar
isn't the ar10 in .308? i've heard good things about rock river AR's, especially the 10.
"COOL PRIUS!" - Nobody Ever
Old 09-18-2012, 08:41 AM
drunk and stupid
HHI944's Avatar
Daniel defense?
Old 09-18-2012, 10:07 AM
nynor's Avatar
Daniel defense?
oooooh..... pretty.
https://danieldefense.com/rifles.html
Old 09-18-2012, 10:54 AM
B58/732
Irrelevant.
Irrelevant. Seriously.
Nope, you're paying for the name printed on the side.
I have never seen nor heard of a metallic AR lower failure of any kind. I shoot .458 SOCOM through a Rock River upper mounted on a polymer lower made by Cavalry Arms. Several hundred HOT rounds through it and the fit is still tight with zero deformation anywhere.
Hell, you can confidently mount a .50BMG upper on a standard (much less sturdy) AR-15 lower without fear of damage.
What you want is a lower that uses the Knights pattern (Magpul magazine compatible). Lower strength is not a concern, unless you plan to use your rifle as a club--in which case your barrel will bend first anyway.
Using the Rock River lower will limit you to RRA components.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-18-2012, 11:20 AM
nynor's Avatar
OMG! you can put a .50 BMG upper on an AR15 lower?!?!?!?!
http://i205.photobucket.com/albums/bb181/giftedgiver/DSCN0121.jpg
Old 09-18-2012, 11:59 AM
B58/732
Yes, most are single-shot bolt action. However, there are even magazine fed ones:
Tactilite T2 Upper Receiver
ΜΟΛΩΝ ΛΑΒΕ
Old 09-18-2012, 01:18 PM
red-beard's Avatar
What is the advantage of the Magpul design? I have 10+ M14/M1A magazines...
James
Old 09-18-2012, 01:48 PM
I've shot AR-15's, and M-1 carbines. (LOVE that M-1 carbine, tons of fun, working on justification for owning one.) I've also shot a 760 Remington in 30-06. I'm not a great shot, but I'm not terrible. With that 760 I was very disapointed with my accuracy when shooting offhand and trying for quick follow-up shots. Kind of like Hickock45 shooting in the backyard at different bullseyes, except he can hit those quick follow-up shots. I haven't shot an AR-10, and maybe the platform just keeps you on target, but offhand a .308/.30-06 pushes me around. It isn't at all like the AR-15/M-1 carbine that allows me to bang away. Are you guys able to shoot the larger caliber ARs accurately and quickly offhand at a distance?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 09-18-2012, 01:55 PM
red-beard's Avatar
I've been reading on the advantage of the AR style receiver and stock. By keeping the stock inline with the barrel, there is less tendancy for the muzzle to climb after the shot.
James
Old 09-18-2012, 02:01 PM
So, how quick and accurate are the offhand follow-ups with the M-1A? I'm not convinced I'm quicker with a pump than a bolt when accuracy counts.
Old 09-18-2012, 04:29 PM
B58/732
Lightweight
Indestructible
Cheap
Reliable
44MAG.com - DPMS - Magpul PMAG 20-LR 7.62x51/.308 20rd Magazine Black
http://www.youtube.com/watch?v=rdesKUSUchA
ΜΟΛΩΝ ΛΑΒΕ
Old 09-18-2012, 04:33 PM
drunk and stupid
HHI944's Avatar
Their factory is about 30 miles from me.........palmetto armory also makes receivers and has a store about the same distance
Old 09-18-2012, 05:29 PM
crb07's Avatar
Quit screwing around, order this;
PredatAR
4 month wait! Weighs the same as a lot of 5.56's.
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 09-19-2012, 07:11 AM
red-beard's Avatar
I guess all of you guys have unlimited funds!
PredaAR - almost $3K
Kinght - $5-6K
Geez, the Armalite AR10 I'm looking at is $1200!
James
Old 09-19-2012, 07:25 AM
nynor's Avatar
Windham Weaponry Online
Old 09-19-2012, 07:13 PM
Registered Abuser
MT930's Avatar
The Armalite is the best value, from what I have seen.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 09-19-2012, 09:04 PM
