Burn the fire.
Tru-Gas in our cars
I've done a search and have been unsuccessful. I'm considering picking up a case of Tru-Gas from the local hardware store and mixing it in with normal fill-ups for my car and motorcycle.
It's supposed to be 92-Octane and have ZERO Ethanol. In CA since there are no Ethanol-free pumps available to the public, what are the positives and negatives of using this as a supplement? Positives I could imagine would be slightly improved fuel economy and more potential energy from the fuel. Negatives... Emissions? The stuff is cheaper than most Octane boosters off-the-shelf at the FLAPs.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
RETIRED
If it floats yer boat. Unless backed up by a dyno it's all snake oil.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bill is Dead.
What is Tru-Gas?
Do you mean this stuff? TruFuel Real, pure gasoline (petrol) has an energy density of 34.2 mj/litre Diesel fuel/residential heating oil, 37.3 mj/L 100LL Avgas, 31.59 mj/L Gasohol E10 (10% ethanol 90% gasoline by volume), 33.18 mj/L Jet A aviation fuel/kerosene, 33 mj/L If you're worried about ethanol, just precipitate it out of solution. Not hard to do.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Burn the fire.
That's the stuff... Looks like the cases sell for less direct than Lowe's sells for. I've got an 81 SC I'll be resurrecting - I'll try running this in the tank with some 91.
Senior Member
If you do not have a cat on the car, put aviation gasoline in it from time to time.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
It says right in the FAQ not to use it in cars. It seems like it's meant for 2 cycle engines.
If you're worried about gas with ethanol in it, why not just buy yourself a barrel of gas from your local race gas distributor? (VP Fuels around here). You can specify your octane and leaded/unleaded. $0.02 |
Registered Usurper
You probably know this, but, ethanol issues aside, boosting octane won't automatically enhance performance in your SC as it might in a newer car, i.e. you'll have to experiment with timing - octane boosters/higher octane gas only allow for greater spark advance without detonation.
'82 SC RoW coupe |
I see you
All of the above valid arguments aside, you'd need to add a BUNCH of that stuff to every tankful to offset 10% ethanol. ala' v1/v2 : c1/c2 IIRC
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Now in 993 land ...
Your SC is made to run 87. It will burn today's gas just fine.
G |
