-   -   Shaving down a Drawer (http://forums.pelicanparts.com/off-topic-discussions/708242-shaving-down-drawer.html)
RWebb 09-25-2012 03:10 PM
I have a drawer (already made up) that I would like to fit into an opening that is just about 1 mm too low for it.
So, I want to shave the height of the drawer down by about 1/8" -- I have a router and a router table, but have no other woodworking machines, no table saw, bandsaw, no nuttin'
What is the best way to do this while minimizing damage or ugliness to the drawer?
lane912 09-25-2012 03:17 PM
carefully-
id10t 09-25-2012 03:40 PM
I'd get a cheap planer at home depot, lowes, etc. and use that on the top of the drawer
Amail 09-25-2012 04:02 PM
Hand plane. I've got a nice block plane I can send you if you like, but you may know someone local with one.
RWebb 09-25-2012 04:09 PM
Thx but I have a hand plane -- it seems like a less accurate (flat) way to do it and more work (?)
Amail 09-25-2012 04:18 PM
A plane is a very accurate way to bring a board to the right size. You can take off a few thou at a time, you'll get your 1/8" in no time.
Make sure the sole is smooth and clean and the blade is razor sharp. Fluffy curls should come out if it's set up right. Go "downhill" with respect to the grain, you don't want to dig into the grain and raise a splinter.
Once you get in your rhythm, it can be therapeutic. You'll find other things to plane.
Zeke 09-25-2012 05:08 PM
A router and router table, if that's what you have.
dad911 09-25-2012 05:09 PM
Make the opening 1/8" bigger.... ;)
Or block the drawer level so you can use the router table to take off 1/8"
RWebb 09-25-2012 05:27 PM
ok, but my question relates to how I support the drawer so it doesn't fall down as I cut away the ends & sides on the router table
ideas?
look 171 09-25-2012 05:32 PM
Originally Posted by id10t (Post 6997204)
i'd get a cheap planer at home depot, lowes, etc. And use that on the top of the drawer
noooo
look 171 09-25-2012 05:37 PM
Setting up the router table maybe more time and trouble then its worth. Do you have a straight cutting bit? To buy it, its 15-20 bucks. If you have to ask how its done on a router table, then it might be a bit dangerous for you. You will need a fence for this. Take it to a cabinet shop and ask to have it trim down. it should take no more then 2 minutes. THat includes setting up the fence.
Red88Carrera 09-25-2012 05:38 PM
Put something inside the upside-down drawer. That way the drawer won't ride on the table, the object inside will. You can adjust the bit height as needed to achieve 1/8" cut. No fence needed either.
look 171 09-25-2012 05:48 PM
i suppose this will need a straight or flush trim bit? That will pull the stock into the router throwing it across the room.
Red88Carrera 09-25-2012 05:55 PM
You'd be using the router like an endmill. No reason that the bit would grab the workpiece.
look 171 09-25-2012 06:02 PM
Most router accidents happen when the work piece is grabbed by a router(bringing the operator's hand with it) without a starting pin. Keep in mind that the router is spinning at 20,000 + RPM. An endmill is, maybe 1000rpm? Big difference.
Red88Carrera 09-25-2012 06:06 PM
Here a quick sketch of the idea. I agree, if you're afraid of the tool, or don't respect its power, don't use it. I've probably routed miles of profiles, and never once came close to an accident. You need to secure the workpiece.
http://forums.pelicanparts.com/uploa...1348621527.jpg
look 171 09-25-2012 06:13 PM
Safer if you set up a fence and cut off the top of the drawer with a straight trim bit. Another word, run the drawer between the fence and the cutter. The chance for a kick back is reduced greatly. very little tear out.
javadog 09-25-2012 07:32 PM
Have you considered making the opening bigger?
JR
LWJ 09-25-2012 07:35 PM
I vote block plane. I have a number of these and they are one of my favorite tools.
Other options would be a simple orbital or belt sander. I would prefer orbital even though it is slow. The results would be better.
The router is a lot of power and opportunities for error - including your hand. If you just have a router table, I will assume it is a smallish one. Even less safe.
Go slow. Go careful. Be clever about this not impatient and you might save your drawer and your hand.
Good luck.
Larry
dad911 09-25-2012 07:53 PM
ideas?
posting a pic would help.
I don't suppose the front (drawerface) comes off?
A red88 said, put a box or something square in the upside-down drawer, so it sits level.
But frankly, that is something I probably wouldn't do, too shakey of a setup.
You could also set the fence (expendable piece of wood, with 1/8" of the routerbit sticking out), and rout off as much as it can reach(three sides), and finish it off with a handsaw or sander, etc. (cutting with the side of the bit, not top)
