LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average.
Detached Member
Hugh R's Avatar
Question Dropping PDFs into a Word document?
I'm trying to drop a 7 page PDF into a Word document. It seems to only want to drop the 1st page into the document, and online help seems to confirm this. Any workarounds? Thanks, I don't write reports too often anymore.
Hugh
Old 10-12-2012, 03:00 PM
Don Plumley's Avatar
break the seven page document into seven files. Or generate the word doc with 7 blank pages, output a pdf then combine.
Don Plumley
M235i
Old 10-12-2012, 03:09 PM
Detached Member
Hugh R's Avatar
I generated 7 blank pages and it only inserted the first page. How do you break a 7 page PDF into seven files? Do I need the whole Acrobat, or can I do it with the "reader"?
What I did is "insert object" and select the file.
Hugh
Old 10-12-2012, 03:15 PM
závodník 'X'
intakexhaust's Avatar
Might now help today but read somewhere MS Word 2013 will have lots of flexibility with PDF merge, edit, etc.. Another cheat for your short PDF is to use the snipping tool for each page, convert to an image and then paste into the Word doc.
edit- Forgot to mention the free numerous PDF creator and cracks available. Search C-NET or google for them. Some of these little freebie programs work quite well.
Old 10-12-2012, 03:21 PM
I don't know about Reader, I have the full version (and on a mac, preview lets you add/subtract pages by dragging). If you email me the doc, I'll break it up.
I use a tool called PDF Creator (freeware) on my PC to print PDF files; it seems to let you edit PDF's as well if you'd rather go that way.
Don Plumley
M235i
Old 10-12-2012, 03:22 PM
Head416's Avatar
You could install CutePDF - PDF printer, you 'print' anything to it and the output is a PDF file rather than a piece of paper. Then print each page of your PDF one at a time to create 7 separate PDFs. Not sexy, but it'll get it done.
Old 10-12-2012, 03:33 PM
Head416's Avatar
Or PDF Creator mentioned above to do the same thing.
Old 10-12-2012, 03:34 PM
Detached Member
Hugh R's Avatar
Guys thanks
I'm doing this work moon lighting for a small consulting firm. Let me try them first. Don, I really appreciate your generous offer. This may well be an on-going small side gig. I need to see if they have anything first.
Hugh
Old 10-12-2012, 03:35 PM
Used Up User
imcarthur's Avatar
Do you have to preserve the formatting? I just had to Anglicize a Frenglish white paper pdf. I just copied & pasted the text into Word & did my editing & reformatted it. Probably more work then you are looking for however.
Ian
'87 Carrera Cab
Old 10-12-2012, 03:49 PM
Detached Member
Hugh R's Avatar
I'll try scanning each page as a separate document and then drop each one in. What a pain, with the lab reports, chains of custody, etc. about 20 pages.
Hugh
Old 10-12-2012, 08:50 PM
The Unsettler
stomachmonkey's Avatar
Why do you need to insert a PDF into Word?
Serious question.
"I want my two dollars"
"Brandon Won"
Old 10-12-2012, 08:56 PM
Send the file over, I can break it up in five minutes...
Don Plumley
M235i
Old 10-12-2012, 08:59 PM
Or the easier way is to generate your word doc, save it as a PDF, then we can drop in the scans. Unless you want the PDF's to sit inside header/footer of your source document.
Don Plumley
M235i
Old 10-12-2012, 09:00 PM
Detached Member
Hugh R's Avatar
Serious question.
Laboratory reports are emailed to me as a PDF.
Hugh
Old 10-13-2012, 05:18 PM
