90+ psi is not even normal on my cummins truck let alone a ford 1/2ton. I have never seen an E-load that says anything 80psi max on the side. Am I mistaken?
Two things: 1) Even though their expressed rating is at 80 psi doesn't mean they can't handle more pressure (or load) 2) The 80psi rating is the COLD pressure, and they're expected to run 5-8 psi higher when warm. So if Vash took the pressure after driving, it very well could have read 90. You'd have to use a pretty high quality gauge to be accurate at near 90 pounds too.... not a stupid little stick pen gauge.
I love you guys outside this forum ![]() -Eric |
Senior Member
If you are running real 10 ply truck tires on the puppy, this pressure is normal.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
